Static noise in volume control
I have an NAD 7250 PE Receiver  It's about 19 years old. As I turn the volume knob I hear a static noise. It use to go away as the amp warmed up but it now continues even after an hour.  The noise comes and goes more coming than going at this point. I tried a spray into the volume knob area (pulled the knobs off) no effect. I have opened the outside case used air to clean the inside. Yes lots of dust etc.  I  don't see any easy way to get into the volume control unit.
Suggestions??
  • Anonymous Mar 20, 2009
    I have the same problem. I think heat might be the cause of the problem?
  • 20 Answers
SOURCE: klh model 52 audio receiver
Open the receiver and locate the potentiometer for the volume. There should be small openings in which you can spray electrical contact cleaner. The spray can be found at any electronic supply store (Radio Shack). Make sure the product says no or zero residue. I use a product called "Electrosolve". After spraying, immediately rotate the pot back and forth a few times. You may need to repeat this process two or three times. You might as well hit the other controls while you're at it. If several attempts don't eliminate the problem, the pot will need to be replaced.
Posted on Oct 11, 2007
SOURCE: Speaker noise
The contacts on the volume control (potentiometer) get oxidized over time on any analog rotary volume control. With the power off, crank the volume control back and forth real fast for a minute or two, this will do the most cleaning of the contacts that you can do without access to the insides. Ultimately you'll probably need to sprary some tuner wash/tuner cleaner or other electronic parts cleaner in the know (with the electricity disconnected) and then work the knob back and forth. Tuner wash bottles are available at electronic specialty stores or radio shack and usually have a long extension tube (like what comes with WD40). You might be surprised where you can reach with the extension tube.
Posted on Sep 01, 2007
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
SOURCE: Pioneer Stero Receiver model SX-3700-
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
Monster80
  • 463 Answers
SOURCE: burst of static when turning on sherwood s7300 receiver
Hi there.Alot of times these old amps on there power board will have dust build up on them.Try this,Fully blow the amps on/off button and every other place you can get at..I hope this may work for you.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Posted on Mar 31, 2009
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
Mackie 450, signal light off, Sound only comes out when amp. turned up above 75%, when usually used at 40-50%. too loud at 75% and UP, does not Work at ALL below 75%. only 2 years old, with 25 uses... i...
Doesn't sound like a fuse. They don't fix themselves when you reach 75%.
Try shaking the volume knob while in the 30-50% range and/or try (with the power off) rotating the volume knob numerous times from 0% to 100%. If when you plug it back in it responds ANY differently, you might have a bad volume potentiometer. If when you shake the knob you hear static or intermittent sound, you have a bad volume pot.
The only other thing I can think of is that the wiper of the volume pot is not in contact with the windings inside the pot until you reach the 75% mark. When the volume comes on at 75%, does it start off kind of "static" then come in loud and clear? Also try this.... adjust the volume pot to 74% (or when the sound just begins to come on). At this point shake the knob. If you hear static, replace the volume pot.
Unplugging it when still on shouldn't cause any damage... in fact it probably hasn't considering it works at 75% plus.
Mar 14, 2008 | Audio Players & Recorders
Eliminate static noise from TC200 volume knobs
It's usually caused by a dust and residue inside the volume control itself. Sometimes you can use a contact cleaner sold at radio shack and online. It's an aerosol with spray tube you attach to nozzle on the can. Sometime you can remove the knob and spray down the shaft. You may have to remove cover from recorder and direct spray in the opening next to the wire plug ends on the control itself. Just spray and move the volume control up and down while spraying. Be careful not to get on the plastic exterior of the player. If the control is sealed up too good this may not work. If not and you really like the recorder just order replacement thru radio shack or some other electronics store. Most of the time just a pair of pliers and removing a couple of wires to change.
Apr 02, 2017 | Audio Players & Recorders
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Right channel has static like noise.
Since no specific model number is provided I can only offer generic advice.
Static noise can be due to radiated noise in the environment leaking into cabling or it could be a dirty mechanical connection or control like a volume or balance knob or an oxidized contact that you rarely use, like a Tape Monitor. I'd turn the unit off and reseat every RCA connector with a twisting motion, rotate and flip every switch throughout its travel a number of times and see what happens.
Dec 27, 2010 | Philips Audio Players & Recorders
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
Dec 03, 2009 | Tivoli Kloss Model One AM/FM Radio
My Stereo integrated hi fi amp is giving a crackle when output from certain devices - like a build up of static at intervals. It is quite old NAD amp - is this a sign of transistor failure, is it worth...
This sounds like you may have a lot of solder connections on the amp board and the power supply board to be resoldered. After a few years of using the unit they can get heat stressed and develop cracks in them. The sooner you get this fixed the better. NAD is a very good brand of stereo and in most cases they are well worth getting fixed. If the stereo is used for too long it can develope some component break downs that would cost much more money to repair.
Sometimes the static or crackle sound is just the volume control or other controls like the balance or teble or bass controls that just need to be cleaned with the proper type of electronic contact cleaner.
I hope this helps, have a nice holiday season,
Dave
Dec 13, 2008 | Audio Players & Recorders
How to scan frequencies quietly
Yes...adjust the squelch control. This is usually a knob adjacent to your volume control. This should eliminate the static noise and you will only hear audio when someone is transmitting.
Nov 17, 2008 | Uniden BC72XLT Handheld Scanner
Pioneer Stero Receiver model SX-3700- Static noice when adjusting the volume control knob
Apr 04, 2008 | Audio Players & Recorders
Kenwood am/fm stereo receiver kr-596
theres a fuse that blew.. ive had to replace mine three or four times. just open it up and the fuse will be somewhere close to the volume knob
Dec 30, 2006 | Kenwood 104AR Receiver
323 people viewed this question
 Grubhead
Grubhead
