Question about U-Line 75R Refrigerator
Lighns on - nothing else
I have a U-Line 75R. It has stopped working, although the light comes on when you open the door - so there is power. When we first got the refrigerator, it did the same thing. The service guy came out, said it was the defrost timer, and reset it. The unit has worked fine since (about 5 years). Assuming that this is the solution this time, how do you "reset the defrost timer?"
  • TimnAlita Jan 05, 2008
    Ditto! I have the same problem, lights on but not cool. Just had an electrician stop by and diagnosed the thermostat control is the problem. Anyone have a part number so I can order one or at least sound somewhat knowledgeable when calling around? (This refrigerator has been discontinued according the the U-Line website.) Thanks!
The 75R does not have a timer. The fan & compressor are powered on the same power leads, downstream from the thermostat. Interior light operation confirms power to the unit. It does sound like thermostat could be the problem. Visit www.u-lineservice.com to contact U-Line's Support Website.
Be careful, the thermostat does switch line voltage (120VAC). You must unplug the unit to service
Posted on Jan 02, 2008
It's likely the thermostat. My parent's just diagnosed their 75R for that. Jumpered across the thermostat connections and the compressor and fan kick in.
Posted on Dec 27, 2007
Well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Posted on Dec 14, 2007
1999 Corolla..........365,000 KM!!!!!!!!!!! Today all 4 power windows AND Power door lock stopped working. Of course its around freezing and 2 of the windows are slightly open!!! Nothing else seems to...
First I would check the fuses and relay. Second I would remove the interior door panel and check the connector pins on the motor to the window. Should that not work, you can disconnect the motor and force crank the window up. Although it sounds like a fuse/relay issue as they seem to be the only items not working. Let me know.
Mar 25, 2011 | 1999 Toyota Corolla
U-line 75R won't cool but light works. What control gets replace
It could be a lot of different things. Is the compressor even turning on?
I sorry to say you may have to call someone on this one.
I hope this helps.
Apr 19, 2010 | U-Line 75R Refrigerator
Does not cool
Lights on but doesnt run? Replace the control
Sep 28, 2009 | U-Line 75R Refrigerator
My U line model 2015rs just quit working. Power
Thermostat is more than likely bad. Nothing runs but light is on
Sep 28, 2009 | U-Line 15R Compact Refrigerator
Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Aug 11, 2009 | U-Line 75R Refrigerator
Uline 75R refridgerator stopped working
Sounds like you did everything right
Jan 24, 2009 | U-Line 75R Refrigerator
U-Line 75R Regrigerator
most cases is bad temp control (90%) or door gasket has a open gap.
Sep 08, 2008 | U-Line 75R Refrigerator
U-line refrigerator model u-1175rw
E3 stands for door open longer than 20 minutes, It may be bad door switch, door switch magnet misalign. You can test the door switch when you open and close the door, it should make a clicking sound, if not, you door switch either is bad or misalign.
Jul 21, 2008 | U-Line 75R Refrigerator
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
U-Line 75R Refrigerator Logo
438 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
