Question about Astar LTV-3201 32 in. LCD Television
Astar LTV-3001 30 inch
My tv turned off and won't turn on, I see on here its happened alot with these tvs, they say its usually the power board, is that my problem, and how can I get it fixed about how much do power boards cost?
  • 2 more comments
  • harryjena Jan 03, 2008
    Sorry but I have NO IDEA what that means! What and where is the power supply?
  • JeanB Feb 29, 2008
    Hi, When I turn my tv on nothing happens. I can see by the power light that its on, but the screen remains black and there is no sound. It is just 2 yrs old. What do I need to fix this, Thanks for your help.
  • lechugita May 11, 2010
    when You turn it on , the Astar logo come up on the screen. after that have only sound and no picture, I check power supply and all cap and voltage are OK.
  • Boonys P
    Boonys P May 11, 2010
    Easy to get to power supply and replace if you have a diagram of location of the buffer cap. Please give location description of the BUFFER CAP on the board .... THANKS!
    New Friend:
Is there anywhere online to buy the power board and/or capacitors?
Posted on Mar 11, 2010
    Problem Solver:
  • 28 Answers
Hello friend,
If your power board is burned then you need to replace the whole power board $65 but, if you power capacitor burned then replace only the capacitor $15. any question 323-767-6030.
Posted on Dec 10, 2008
  • tietivan578 May 25, 2011
    Hello Guys,
    I am worked in Astar Co till they clossing down, Any Astar brand electronis question or help? call me at 323-868-3303 or email me [email protected]
  • 3 Answers
I work for a tv repair shop and we got three AStar LTV-3001 tvs given to us. in one of them we replaced the 8 caps (4 @ 2200uF and 4 @ 3300, which we actually replaced with 10 or 12 caps that added up to the same amount) and that fixed it. the other two need a MOSFET that is impossible to get ahold of. so they need the power supply replaced. i am currently looking for one and i will comment again if i find one.
Posted on Aug 16, 2008
Who can service the Astar brand in Michigan ?
Posted on Jun 09, 2008
Cuando prendo el televisor sale la voz y no da imagen,tambien cuando trato de prenderlo no prende por favor nesecito ayuda
Posted on Jan 29, 2008
  • 21 Answers
Remove the back pedistal mounting screws and back cover. The PS board is under the metal protective cover at the center of TV guts, The CAPs that are referred will hopefully be identified by zjut soon but my guess it is the largest black caps 100uF 450W. 3 of them. around the transformers but wait for confirmation...
Posted on Jan 20, 2008
  • 1 more comment
  • Boonys P
    Boonys P Jan 21, 2008
    Astar 30" LTV 3001--- Others have been replacing the 2200uF 25V caps All of them! I am going to replace all with 35V caps to have greater resistance to failure. 105C heat rating is also a factor. A set of 1" vent holes cut out of the pack panel will keep it much cooler and I may even add a small cooling fan.
  • Boonys P
    Boonys P Jan 22, 2008
    Tips, LCR meter revialled 4- 2200uF were bad, and 4 - 3300uF caps bad and 1- 1000uF(10v) cap bad, some were bulged on top and some not. If you don't replace all, you must test all. If you want to be sure and save time replace all 1000uF-10v, 2200uF 25v and 3300uF-35v caps. I would test the two 47uF-450wv just to be sure, these are pricy and harder to find. Remember to buy 105c rated caps and these are all radial type. Results in next note.....
  • Boonys P
    Boonys P Feb 08, 2008
    10 electrolytic Capacitors were replace and it has been working for 3 weeks now. Also, by mounting a computer fan on the rear, over the power supply will keep it cool, thus preventing cap breakdown from heat. Good Luck!
  • 106 Answers
It's easily to fix the problem. Just replace the buffed capacitors on your power supply board.
Posted on Jan 02, 2008
  • LX Jiang
    LX Jiang Jan 03, 2008
    If you find the fuse (5AL @ 250V) was blown, then check the smart power IC F9222L. If this IC is shorted to ground, replace this IC also.
SOURCE:
WILL NOT TURN ON,BUT HAVE GREEN LIGHT
Astar LCD tv are famous using cheap capacitors in their power supply board as componnents,these capacitors are leaking gases,they bulges up,puff up.That why one ur tv is dead.The other tv is unstables changing channel on it own.U know basic electronics,and soldering?Take both of ur tv aparts.Searches all around the power supply board.Look for these bulges up,puff up capacitors,replaced these capacitors.Both ur tvs will work normal again.Or tries websites like Shopjimmy.com,Ebay.com to buy two whole refurbish power supply boards to replaced each one of ur tv.
Jul 09, 2010 | Astar LTV-27BG 27 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
There is Part Store having Astar LTV-27BG boards in stock. Please check out might help you to power up back your TV.
Regards,
Aug 28, 2008 | Astar LTV-3201 32 in. LCD Television
Mind of it's Own
Apr 29, 2010 | Astar LTV-3201 32 in. LCD Television
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected]
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
I repair these power supplies. Write to [email protected] if you require further assistance.
Jan 03, 2009 | Astar LTV-3001 TV
Can't turn the volume up or down
Hello Sir,
you need to replace the tv main board part (whole mother board).
any question call 323-767-6030.
Nov 16, 2008 | Astar LTV-19BG TV
Astar LTV-2701 27
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Jan 13, 2008 | Astar LTV-3001 TV
Astar LTV-3201 32 in. LCD Television Logo
689 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
