Question about Toshiba 43H70 43" Rear Projection Television
Audio Recently I have heard a clicking or popping static electric type of sound coming from the tv. Any ideas or suggestions?
    Problem Solver:
  • 8 Answers
Sounds like a failing audio IC, or capacitor in the audio circuit, probably an IC or bad connection @ the IC. technical schematic or the shop if one is not familiar with component repair!!
good luck stereo tech
Posted on Feb 03, 2008
When I turn the tv on, it sounds like static electricity coming from the back.
Check its final anode connection for arcing. You have to replace the final anode rubber boot, if arcing is here. Seek tech support. This is a dangerous work, for an un-experienced one.
Jun 22, 2012 | JVC Televison & Video
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
My car was off, key out of ignition. I heard my
sounds like the amp chip has failed im afraid
Jul 14, 2009 | Car Audio & Video
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Problem with Samsung HLP 4667W/HL DLP TV
As a general rule, popping sounds are bad news. This means a static charge, electrical shot, or insulation problem. Or a combination of these issues. Many times this occurs when the electrical circuit boards components break down and degradation occurs. In some cases a discharge of electrical energy (like when you get a shock from a door knob) may hop or jump between components and make a noise, whereby that popping sound occurs. In some cases, high energy discharges can cause an electrical fire, so be aware of the dangers. The fix can only be done by a professional with the skills to trace the problem and do a repair.
Jan 13, 2018 | Televison & Video
Samsung HLN567W whining sound from front bottom middle of tv
Hi
Here is the steps that I will suggest you to check.
Mute the sound completely and make sure sound is not coming from speakers. If you totally concluded that sound is not coming from speakers probably its from internal coils on the circuit or high voltage cable leaks statical electricity. that case asking assistance a qualified hands on technician will be best idea.
Good Luck
Jan 04, 2008 | Samsung DLP HL-P5663W 56" TV
No sound on sharp aquos LC32D6U
The problem is the silicone grease under the audio IC has melted and is shorting the audio circuit. To fix this, you'd have to clean the melted residue off the audio IC. It is a complicated job and I suggest calling your local Authorized Sharp service center to do this repair.
Jan 03, 2008 | Televison & Video
Mitsubishi 65831
sounds like the projector globe is gone. i think you will need to replace it. if you are lucky there should be a pannel on the side or rear of the tv that allows you to replace the globe. pricey though.
good luck
smeags
Dec 31, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Toshiba 43H70 43" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
