12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to
#*7370). It is useful in some cases, for example when the phone cannot
reboot.
The trick is Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons... reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
You can hard reset the phone (Factory Settings) This will reinstall the operating system inside the phone back to how it first was. (internal memory gets formatted then the rom reloads the os back) (Solves all kinds of problems.)
Switch the phone "OFF" Hold "3" (button) + "Green Call" (button) + "*" (star button) Switch the phone "ON" while holding the above three buttons. Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
If you ever tried debranding the phone youself and made a pigs ear of it, and your phone says " phone start up failed, contact the retailer" below is a way of reformatting the phone back to the original factory settings.
1 power the phone off, 2 press and keep down the keeys green/talk + '3' + '*', - power on the phone at the same time 3 release the keys when the formatting starts.
