Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Water on washer on cold real slow
By boatyg661 on Aug 21, 2009
Water on washer on cold real slow took out the screen still slow, think it mite be the solenoid.
Solution #1
posted on Aug 21, 2009
Not Rated)
rollpoll
Rank: Guru
Rating: 90%, 44 votes
Hi, yes you are right, it,s your dual water solenoid valve, but before replacing it, remove/disconnect from machine, and put it apart, check to see if anything get between, valve and plunger, could be just mechanical, after cleaning replace valve and test machine, if same problem continues, change water solenoid valve, could be faulty.(burnt out coil) always unplug/disconnect your machine/washer before attempting any repairs. .good luck
Was this helpful?
Yes
No
Solution #2
Not Rated)
canbruce75
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 839 votes
Yes, if the screens are clean then it is most likely the solenoid, most likely on the cold water side. It can be tested for continuity with a multimeter or ohmmeter. A lack of continuity will mean a bad one and the water inlet valve assy will need replaced. Best wishes.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
each time my washing machine agitates or spins i smell some kind of electrical burning.
Answer
The drain pump seems to run for a very long time and a slight smell in the laundry room is present... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
