Question about Estate TAWS800JQ Top Load Washer
Washer machine when I go to wash clothes and the water is draining, it is emptying into my bathtub. I live in an old house and all the pipes are connected.
  • 99 Answers
You have a clog in your drain system and when you have a large volume of water it will back up into your tub and possibly your toilet. the only fix would be clearing out your clog.
Posted on Mar 29, 2008
SOURCE:
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
My washer doesn't drain the water... when i take the clothes out they are soaking wet and the washer has water in the bottom. it worked two days ago...
I had this problem & found it to be a blocked outlet pipe ( the flexable pipe where the water emptys into the drain) .Unscrew the clip that attaches it to the pump & clear it out.
Dec 20, 2009 | Whirlpool Washing Machines
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Draining issues
Most modern washmachines have a Drain solenoid that opens a valve so the pump can empty the machine, but that is not alwats the case - especially on front-loaders.
In any case, you'll need an 'Up and over'. This is a U-shaped gizmo that shapes the 8-10' drain hose into a U, and hangs on a nail in the wall even with the top of your machine.
This allows the end of the drain to lie on the floor at the drain end without SIPHONING all the water out. Weigh down the end of it down or it will 'dance' when the machine empties and blast water all over ;-).
To contain this, remove the screen on the floor drain and poke the hose in, pump into a bathtub or shower so the water has a place to go, or Get a large plastic storage bin with snap on lid to catch the water and let it out slowly. Make a small hole in the bottom corner and a hole to fit the hose on the other end, poke it in and duct tape both sides so it cannot move. When the machine drains and water blasts in it will fill the container really quick, and then slowly leak out the corner hole into your floor drain. Make the corner ole larger to drain faster. We don't want it to fill again, and again before it can empty ;-)
Nice and tidy (and cheap if you get the tape and bin at Dollar Tree ($1.00 ea.)
Mar 26, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Estate TAWS800JQ Top Load Washer Logo
35 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Bobby G
Bobby G
Steve Allison
Steve Allison
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
