Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson Stylus Printer CX4600
Printer was not used a lot for a couple of months. I put in all new ink cartridges but the only color that will print is black. Green does print but comes out aqua. Red will not print at all.
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Posted on Jan 02, 2008
SOURCE:
Just put new ink cartridges in, but yellow is out. Do I need full yellow cartridge in order to print? Printer is not printing.
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 25, 2010 | Epson Stylus CX4600 All-In-One InkJet...
My printer was printing fine, iloaded new ink
Epson does not like Generic/Compatible Cartridges
MUST BE GENUINE
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Put back in Genuine Cartridges, and see if it works. This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 04, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Lines in picture when printing
In the print queue there is an advanced tab that takes you to see how much ink you have etc. Go to the maintenance tab and select the cleaning option. Be aware that this uses up a lot of ink doing this. But once you have done it check the nozzle printout to see that it is continuous in its printing on all colors. keep at it till it is.
To prevent this from happening in future keep the printer on Epson dont say that turning it off can cause the ink to solidify in colder weather.
I have come to leaving mibe on 24 hrs a day or taking the cartridges out and then printing a pic till all color is used fromj the reservoir. This has kept my EPSON 90 going for 10 years my Epson A3 died within 3 years from clogged jets
Sep 01, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
Cx4600
Most likely, the print heads have dried up. Because of their ink technology, Epson printers need to be used every 1-2 weeks, even if it's just performing a nozzle check. A nozzle check uses very little ink, but keeps your print heads in good condition.
Nov 20, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
256 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
