Question about Sony SDM-HS73P 17" LCD Monitor
Green light "NO input signal go to power save" than white light at power
That's it....nothing else. HELP
  • 1 more comment
  • jewell4 Dec 03, 2007
    is anyone going to help with this?
  • Anonymous Mar 03, 2008
    i have the same problem, it says no input signal: HD15, GO TO POWER SAVE...WTF
  • vickimcroy Sep 08, 2008
    i have the same problem! this is sooo annoying.. do i just have to throw it away or what?
  • 983 Answers
Check the cable connecting from monitor to cpu is connected properly... try reconnecting it ... ur problem will be solved ...
Posted on Feb 06, 2008
SOURCE:
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
I need a steering column wiring diagram for a 1979 cj5. On the column side of the plug that goes to the steering column there are 8 wires. White, Black, Yellow, Green, Purple, Brown, Light Blue, and Dark...
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Feb 12, 2010 | 1983 Jeep CJ5
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
No kick
It can only be a few things...either it overheated and is in a protection mode...the amp went out... the input line is not supplying input...or the output line is not supplying output. If the input is good...the output that goes from the amp to the kicker itself may have came unplugged. If that is not the case, it may have overheated.
May 30, 2009 | ButtKicker LFE Kit Subwoofer
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
1,042 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
