Question about Epson Stylus CX5400 All-In-One InkJet Printer
Cant find the scan...
There's no scan button on my scanner. it will copy a picture, and print it. but i want to scan it and put it on my computer. i cant figure out how. help please!!!!!
  • 83 Answers
You do not need a button.
Simply open a program and acquire the photos from here...
Example : Start- Programs- Accessories- Paint- File- From scanner or camera...
Posted on Dec 03, 2007
SOURCE:
When I put picture in printer to scan it tells me "computer is not found".
You may have to manually connect your scanner to the computer or set them both up on your LAN. I initiate scanning from the computer, with a program like Irfanview, which is a free download.
Good luck,
Paul
Dec 03, 2015 | Office Equipment & Supplies
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
Printer won't work manually.
Usually, you need to print a test page: go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it. When the test page is printed, you will see some pictures: those are the steps you need to take to make your scanner/copier work. Basically, all you need to do is put the test page in your scanner (as indicated) and press scan. The scanner/copier will then do an alignment and you will be able to copy manually.
Apr 01, 2010 | HP Photosmart C6280 Printer
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
The scan function on my HP F335 is not going to the computer
Install the scanner software and configure the tool that when u press scan button that should envoke the scanner software iin the computer
Aug 25, 2009 | HP DeskJet F380 All-In-One Printer
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
MP 160 Cannon Printer Won't Scan
try checking if you have completely installed all the drivers for your printer. scanning and copying dont usually needs drivers because you can do that even without a computer. but scanning requires your scanner to be read by your pc. try checking for the scanner driver from the cd that came from your printer.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem with scanner
Try to get the scanner operating by using a programme such as paint (open file from scanner or camera) or powerpoint (insert picture from scanner or camera). I have used this with success in the past. I have not used the scan button so I cannot advise you on this.
Hope this at least gets you going with scanning a copy of something and once you have it in these programmes you can at least print it and make some changes that you desire.
Hope this helps.
Youre right - they are a great printer!!
Johnca51
Apr 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Aug 31, 2007 | Canon CanoScan N640P Flatbed Scanner
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
