Question about KitchenAid KESC307 Electric Kitchen Range
Kitchen aid stove problem
Kitchen aid stove stopped working with noise of short circuit.When opened the switch board panel the left rear swith had a burning mark. After replugging in the panel shows no light and when any of the switches is turned on panel shows light but no coil warms up.While keeping the coil button on oven works and when coil button is turned off oven stops working also.
P. Gill,
[email protected]
  • 2 more comments
  • wildfire2397 Dec 23, 2008
    I have a kitchenaid oven that doesn't work Model# KERC507HWH3 any Ideas - sevice people said it would be about $600.00 to fix it ?
  • Anonymous Mar 16, 2014
    my kitchen aid 30" gas range display panel gets dim, goes out then comes back for no reason burners and stove temp are all fine?
  • Anonymous Mar 18, 2014
    recently i have to try many times to turn on the kitchen gas stove
  • Anonymous Mar 24, 2014
    Hi my Kitchen Aid model KGCD 807XBL 01 has the following problems: it kept short circuit, when I turned it on, there is fire, smoke. What should I do?
  • 833 Answers
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
SOURCE:
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
I have a 2006 explorer with the rear sensing system RSS my warning does not work and there is a warning on the dash stating to check rear backup system? The fuse should be good as my heated seat and 4x4...
Have the RSS module checked for DTC'S - diagnostic trouble code's . That should always be the first step . An it is
Reverse sensing system Parking Aid The parking aid system consists of the:
  • parking aid sensors
  • parking aid speaker
  • parking aid module
The parking aid system is activated when the parking aid module receives a network messages from the instrument cluster indicating that the vehicle is in reverse. The parking aid system sounds a warning to alert the driver of stationary objects near the rear bumper when REVERSE is selected. The parking aid system assists the driver in detecting certain objects while the vehicle moves in reverse at speeds less than 4.8 km/h (3 mph). The parking aid system may not detect angular or moving objects.
  1. Visual Inspection Chart Electrical
    • Smart junction box (SJB) fuse 18 (10A)
    • Circuitry
    • Connector(s)
    • Parking aid sensors
    • Parking aid speaker
    • Parking aid module
Do you know what DTC'S are .
Parking Aid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1299 Power Supply Sensor Circuit Short to Ground Parking Aid Module Go To Pinpoint Test C . B1342 ECU is Faulted Parking Aid Module CLEAR the DTCs. REPEAT the parking aid module self-test. If DTC B1342 is retrieved again, INSTALL a new parking aid module. REFER to Parking Aid Module in this section. CLEAR all DTCs. REPEAT the self-test. B2477 Module Configuration Failure Parking Aid Module REFER to Section 418-01 . C1699 Left Rear Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1700 Left Rear Sensor Circuit Failure or Blockage Parking Aid Module Go To Pinpoint Test C . C1701 Left Rear Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1702 Right Rear Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1703 Right Rear Sensor Circuit Failure or Blockage Parking Aid Module Go To Pinpoint Test C . C1704 Right Rear Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1705 Left Rear Center Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1706 Left Rear Center Sensor Circuit Failure Parking Aid Module Go To Pinpoint Test D . C1707 Left Rear Center Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1708 Right Rear Center Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1709 Right Rear Center Sensor Circuit Failure Parking Aid Module Go To Pinpoint Test C . C1710 Right Rear Center Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1742 Rear Sounder Circuit Failure Parking Aid Module Go To Pinpoint Test F . C1743 Rear Sounder Circuit Short to Battery Parking Aid Module Go To Pinpoint Test F . Your best bet , take it to a qualified repair shop . Ford
Jan 02, 2018 | Ford Explorer Cars & Trucks
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
My 2007 Yukon has a problem with the park assist sensors. When I go in reverse sometimes, the warning beep repeats quickly and the lights flash like crazy but nothing is behind the vehicle. Sometimes the...
Check the system for DTC'S - diagnostic trouble codes should be the first step in the diagnostic process . Then reading factory service repair manual how the system works , viewing wiring diagrams .
Object Detection Description and Operation
Ultrasonic Rear Park Assist Operation
The ultrasonic rear park assist system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located in the rear bumper. The object detection system will notify the driver when backing up at speeds less than 8 km/h (5 mph). The object detection system will use the rear parking assist (RPA) display and the radio speakers for notification.
When the ignition is ON and the vehicle is placed into reverse, the object detection system performs a bulb check. During the bulb check, the 3 indicators on the RPA will illuminate for approximately 2 seconds to indicate that the system is working. The object detection system performs a bulb check and operates when the following conditions are present:
• The ignition is ON.
• The vehicle is placed in REVERSE (R) for rear parking aid.
• The vehicle speed is less than 8 km/h (5 mph). At speeds greater than 8 km/h (5 mph), the object detection system is disabled. The red indicator flashes to warn the driver that the object detection system is disabled.
The object detection system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located on the rear bumper. When the system detects an object, one of the following will occur:
• If the object is less than 0.3 m (11 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators flash and the chime sounds continuously for 3 seconds.
• If the object is less than 0.3-0.5 m (11-20 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators are ON.
• If the object is 0.5-1.0 m (20-40 in) away from the vehicle, the amber outside, and the amber middle indicators are ON.
• If the object is 1-2.3 m (40-91 in) away from the vehicle, the amber outside indicator is ON with a single chime when the object is first detected.
Object detection system can detect objects 7.6 cm (3 in) wide and at least 25.4 cm (10 in) tall. It cannot detect objects above the level of the roof.
If the object detection system detects a malfunction, a diagnostic trouble code (DTC) will be stored and the object detection system will send a serial data communication message to the instrument panel (I/P) to SERVICE PARK ASSIST message on the driver information center (DIC). Then the chime will sound and the red indicator on the information telltale center will be lit continuously. The red LED in the rear display will be lit, notifying the driver that a malfunction exists. Message will clear once the driver acknowledges it.
Each object sensor is a three wire sensor that is both a transmitter and a receiver that comprises a signal circuit, a low reference circuit, and an 8-volt supply voltage circuit. The rear object control module supplies 8 volts to the object sensors via the object sensor supply voltage circuit and provides ground via the low reference circuit. The rear object control module triggers the sensors in a sequential loop and after each sensor transmits, the rear object control module uses the echo or signal return to calculate the distance and position of an object from the rear bumper. The rear object control module directly controls the RPA display.
Do you know what DTC'S are ?
DTC B0958 01: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Battery
DTC B0958 06: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Ground or Open
DTC B0958 08: Parking Aid Rear Sensor 1 Left Corner Circuit Signal Invalid
DTC B0958 21: Parking Aid Rear Sensor 1 Left Corner Circuit Incorrect Period
DTC B0959 01: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Battery
DTC B0959 06: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Ground or Open
DTC B0959 08: Parking Aid Rear Sensor 1 Left Middle Circuit Signal Invalid
DTC B0959 21: Parking Aid Rear Sensor 1 Left Middle Circuit Incorrect Period
DTC B0967 02: Parking Aid Switch Circuit Short to Ground
DTC B0968 00: Parking Aid Indicator Circuit
Your best bet , take it to a qualified repair shop.
Feb 04, 2018 | GMC Yukon Cars & Trucks
Park assist shut off intermittantly and now display reads "service park assist" permanantly. Dealer will not fix even tho' was warranty repair in Dec(less than 6 mos later problem was brought to their...
How do you know it's a sensor problem ? DTC - diagnostic trouble code ? Take's professional type scanner to read these DTC'S
Could have other codes
DTC B1008 42: Calibration Data Not Programmed
DTC B1E3A 03: Sensor Power Circuit Voltage Below Threshold
DTC B1E3A 07: Sensor Power Circuit Voltage Above Threshold
There are a lot of other qualified repair shop's besides the Dealer .
Nov 05, 2017 | 2007 Chevrolet Avalanche LTZ
I have a Kitchen Aid refridgerator. My freezer
Hi, Check the rear inside panel of the freezer section and see if there is a frost build up. Also check and make sure the evaporator fan motor in the freezer is running.
If there is a frost build up, remove the rear indise panel and check the defrost heater and bi-metal switch for continuity. The bi-metal switch located on the top of the evaporator has to be tested while it is still cold.
If either of them show an open circuit, it will need replaced. If both of these parts show ok, you will need to replace the defrost timer/board.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Jenn-Air JCB2280HES Side by Side...
Clock and light in oven work but stove and burners will not
Sounds like the wires connecting your control panel to the individual heating elements have either shorted out or been disconnected. Try taking off the control panel board and testing the connections (the four on the sides of the circuit board in the middle, and the two five pin and one three pin connector on the mainboard). If they are good, then your problem lies in the control board itself and will require a replacement from Whirlpool. Depending on if you have the touch sensor board or a push switch, it can run upwards of a few hundred bucks.
May 26, 2009 | GE Spectra JBP78 Electric Kitchen Range
Hello there, My stove beeps repeatedlyand willonlystopwhen Iunplug the stove ... I read that it maybe the circuit board. Is this the problem and can I fix it myself?
Yes trhe stove have a swich behind every knob one of them is bad on the on position, remove allthe knobs and the knob panel to get to the swiches, and remove one at a time intel noise stops thats the one needs changing. or it may be that the are wet.
Dec 05, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Loud clicking sound does not stop
The igniter circuit is stuck the circuit that controls this is shorted out and you cannot likely fix this. The controlling scr transistor is bad. its on the main board. It happens
Feb 03, 2008 | Frigidaire FGF378AC Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
551 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
