Tv tube problem
We purchased a console tv for 25 dollars and it worked fine for one day and then we turned it on a nothing but a line of color going across the middle. The sound is fine help!!!!!
  • Anonymous Apr 23, 2009
    horizontal line aswell, cant service it, what should i do
  • 232 Answers
It`s total vertical collapse, which means 3 possibilities, vertical IC has failed, vertical IC solder connections are broken, the B+ line (voltage to make IC run) to the vertical IC has failed. None of these problems are big dollar repairs, 1/2 hour repair by any qualified tech, Good Luck & Happy Holidays, BMW Rider
Posted on Dec 03, 2007
Philips 60PP9363 colors not right. TV is 5 years old, the convergence appears to be fine in that all of the colors line up fine, but they are not the right shade. The green and blue are both teal, with...
Ur tv look dull in pictures?Ur tv might need it CRT tube coolant replacement.Tries websites like, to buy a coolant kit to replaced CRT tube coolant replacement.
Aug 04, 2010 | Philips 60PP9363 60" Rear Projection...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
PS3 won't show up on tv
first make sure all componet cables match up in color in back of the tv turn on ps3 and try using the remote to change the componet selection of the port your using
May 14, 2009 | Sony Playstation 3 (PS3) Console
Tv is now in faded black and white
Your HT Tansfer is giving low votage to the picture tube. Replace the HT Transformer(don't touch or go near it, it carries 11000 Volts!)....sodeep
Mar 22, 2009 | Samsung HLN5065W 50" Rear Projection...
We have a 25 year old zenith console, pretty old.. but still functional.. we noticed that the tv turns blank to a green screen... no picture just green color shown on the screen, then it will go back to...
Hi and welcome to FixYa,
Initially, your described problem indicates that one of 3 color drive transistors (for the green) has developed either a cold solder (most likely) or an intermittent internal fault (leak). These transistors (or in some cases a single power pack module/IC) are normally found on a small squarish PCB (printed circuit board) at the very rear of the picture tube (CRT). At times, the green blank screen would also have diagonal fine lines or would appear to be overly bright.
In some rare instances, it could be the chroma section (least likely) or in worst case scenario the CRT (cathode ray tube) itself that is faulty (hope not).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 18, 2009 | Televison & Video
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Color switches to b/w, then a click, then color, then b/w, click, etc.
Good day.
I think your problem is with the crt circuit. It is the one on the rear of your picture tube. Some loose connections may occured in there. Also, check if the flyback is arching. Sometimes, the voltage on the flybach itself causes this.
Mar 23, 2008 | Sony KV-27FS13 27" TV
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Nov 18, 2007 | Curtis-Mathis CM27101S TV
Televison & Video Logo
668 people viewed this question
Top Televison & Video Experts
