Question about Motorola Mobility E815
Motorola E815 I purchased a used Motorola E815. The carrier is alltel, and the user that had it before me put a pin on it. Is there any way to reset or override the pin # ?
  • Anonymous Feb 19, 2009
    i have a phone a need a four number combonation
    Problem Solver:
  • 7 Answers
Depending on what is locked, you may find a master reset helpful. If you have time to kill, there are only so many combinations in a four-digit number. It took me less than an hour to hit on it once.
Posted on Jan 24, 2008
    Sergeant:
  • 316 Answers
There is 2 ways
Either contact the previous user and get the pin from them or you will have to take it to a tech and have them reset it back to the default setting
Posted on Dec 03, 2007
SOURCE:
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
Aug 16, 2015 | Motorola Mobility e815 for Verizon /...
Unlock code
The phone can be programmed over the air with one step. First, call *228. Once that finishes, call any number and the programming will be complete. The programming menu is accessed from the home screen by quickly pressing "menu", 0, 73887*. At this point, the phone prompts for the Security Code, which is usually 000000 on Verizon, Alltel, and Amp'd, and 236197 on Bell. However, it's possible that this number could be any number at all. Once in the programming menu, the user can manually activate the phone, configure web browser sessions, GPS, Get It Now, and Test Mode. The security code is not the same thing as the SPC (Subsidy Provider Code). Of the carriers that support the e815, only Canadian carrier Bell Mobility uses a subsidy lock code. Verizon, Alltel, and Amp'd do not use SPCs. The SPC is needed to access any of the services located in the aforementioned Programming Menu. There is no default SPC: it varies from phone to phone. The SPC for a Bell Mobility e815 is located in seem 0055, Rec = 1, Bytes = e. The SPC code is usually a 6 digit decimal based number. If this does not work contact your service provider, as they may have to change the simms or unlock it. Good Luck
Jun 12, 2007 | Motorola Mobility E815
Just purchased new battery and when I tried to charge it my phone shuts off. Why?
Let it fully charge before turning it on for the first time.
Mark
Motorola Support
Apr 30, 2014 | Motorola Mobility E815
I have an ALLTEL Motorola E815 cell phone and I want to remove my number because I have a new phone. Alltel doesn't work using sim cards. Help me. Please.
You can go in to the phone settings and restore to factory defaults. This will erase all your personal info.
Please leave good rating, it is important...
Aug 04, 2009 | Motorola Cell Phones
Motorola q9m shuts down
maybe a phone issue but you can always try to reset the phone to see if that helps, ( power phone off, hold center button, power phone on keep holding center button until master reset screen comes on) , or most carriers like verizon and alltel i know have an update you can download and install from motorola.com ( click on support and then software downloads) may ask for purchase date cust put in a recent date and download is free. both reset and update will erase alll info off phone so back up first before you do them
Sep 02, 2008 | Motorola Mobility Q9m Smartphone
Motorola E815 phone number reset
J'AI UN MOTOROLA E815 ET J'AI OUBLIé MON LOCK CODE C'ETAIT PAS AVEC LES 4 DERNIERS CHIFFRE....AIDE MOI A RESET MON PORTABLE
Aug 30, 2008 | Motorola Mobility E815
E815
You could view the user manual here:User Manual this is for the e815.
If link does not work just write back.or copy and paste this to your browser: direct.motorola.com/hellomoto/nss/productresource.asp?PhoneModel=e815
Hope it will be useful to you.
Thanks
Dec 30, 2007 | Motorola Mobility E815
Security
i dont think so. check with your service provider. alltel customers can block texts from unwanted senders, but not calls.
Dec 11, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
219 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
