Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
High pitch operating noise? gets louder when you use keypad
Hi i know all K1's have some normal operating noise (hold it to your ear when you are not playing any sound) but my daughters gets louder as she uses the keypad.. At night it is annoying even me.. although my daughter who is younger and holding the phone says it gets as bad as those silent ringtones that kids can only hear. Is it a common problem? We have tried taking the battery out for 5 minutes.
  • fiona4kids Dec 03, 2007
    Thanks but she only had the volume at less than half. I took it back to the shop for exchange. Whatever it was kept draining the battery. It needed charging daily.
    Sergeant:
  • 316 Answers
Try ringing the phone and answering the call
then lower the earpiece volume with the side adjustment key maybe your are getting feedback because the volume is too loud.
I couldn't say it was a common prob. I used one of those phones for nearly a year and never had any trouble with it
Posted on Dec 03, 2007
SOURCE:
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
High pitch noise when decelerating
jack vehicle up and rotate one wheel at a time to see if noise is present, let me know what you find
Dec 18, 2015 | 2002 Toyota Corolla
I have a high pitched screaming noise on passenger side of car. I dont hear it all the time, just randomly.
noise is a 100% hands on , eyes and ears on deal.
get it serviced.
we can guess here, there are 3000 parts, all of which can make noise.
Jul 15, 2014 | 1991 Honda Accord
I just got a 540ez. It makes a high pitch noise while cycling up. Is this normal for this flash? ideas to make it quiter?
It is normal for flashes to make this kind of noise, and the more powerful the flash, the louder it is likely to be. I know no way to make it quieter.
Nov 17, 2010 | Canon Speedlite 540EZ TTL Flash
I have a samsung neo 32 inch picture tube tv. When I turn it on there is no picture or sound, but there is a light high pitched noise.
That high pitched sound is likely the Horizontal Output section trying to work. It operates at 15,750 Hz or at the upper end of normal human ears.
It will sound like a high pitched whine.
This is a section or your television that you don't want to fool with unless you are quite familiar with servicing your set. There are very high voltages involved and only a qualified technician should tend to this defect. It maybe easy to fix or it may be quite involved. Get an estimate first then decide to go further or not. There is a potential fire hazard here so don't operate your set until this is resolved.
Zashiban
Jun 23, 2010 | Samsung DynaFlat TX-P2764 27" TV
HIgh pitched sound when accelerating w/ My 2007 Hyundai santa fe
This may sound strange but have someone check out your radio system. Sometimes an antenna wire or wires, when jared loose will make that ear piercing noise. It may not be the problem but it's worth looking into.
Aug 31, 2009 | 2007 Hyundai Santa Fe Limited
My amana washer makes a whril noise when it spines.
UNFORTUNATLY IT IS PROBABLE A SPIN BEARING THAT IS MAKING THE NOISE. THIS IS USUALLY CAUSED BY A LITTLE WATER LEAKING FROM THE CENTER SEAL ONTO IT. IT IS VERY EXPENSIVE TO FIXED AND VERY TIME CONSUMING, PLUS YOU WILL NEED SPECIAL TOOLS DESIGNED FOR THE JOB
Aug 11, 2009 | Washing Machines
Ps3 high pitched noise
forget the xbox, yo have tintinnus or tinnitus, you need to see a doctor ASAP i had this and it went away on its own but you can have it the rest of your life and there is no cure
Jun 13, 2009 | Sony Playstation 3 (PS3) Console
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
