FixYa.com
Tags:
GE Superadio III AM/FM
Milwaukee job site radio
posted by the roofer on Dec 02, 2007
radio only works with batteries.
the radio does not work when plugged in to an electric outlet
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 03, 2007
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 86%, 1971 votes
Depending on the model that you have (JSR 1218?), there could be several versions of a Milwaukee Job Site Radio. If it is a JSR1218, to my knowledge, it only comes in 2 AC power versions: 220-240 and 240. I am not aware of a 120 version, but of course it is really dependent on your local distributor. Pls verify what version and the mains power in your area/region and ensure that they are the same (or in some models, there is a selectable AC voltage setting). You can check the label for the specs/power requirement.
Since your profile indicates that you are in the United States, perhaps the reason it is not working using your electrical outlet and only with batteries is that your electrical outlet gives US standard 120 VAC whereas the radio requires 220/240. If it is so, then checking if it has a 120 voltage selector/setting might do the job. Otherwise, the internal power transformer needs to be replaced (in some models, there is a jumper inside that can be set for it to operate correctly to 120VAC). Alternately, the transformer can be replaced which is not really a critical job and any qualified electronic technician should be able to do the job. Pls consider that a Milwaukee JSR 1218 can be powered by either 12, 14.4, 18 or 28 VDC Lithium Ion batteries, hence the substitute/replacement transformer must matched whatever type of battery is used in your radio (The radio has also a 12VDC output for your accessories). Additionally, the current rating is relatively low at 250mAmps for 220-240 and something like 500mA for 120VAC.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Personal Radios problems?
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
Personal Radios
Audiovox AXR48- find manual?
I can't find a manual for my... Answer This...
Personal Radios
Need replacement earpads for...
Hi, folks....My radio is a few... Answer This...
Personal Radios
Radio display out on 2006...
The sound system on my Harley... Answer This...
Milwaukee Job Site Radio AM-FM...
Customer brought in this radio... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
