Question about Epson Stylus 2200 InkJet Photo Printer
Print head any idea where to get one and/or how to change the print head for stylus 2200?
Compassmicro.com carries printheads for the stylus 2200 and if you take look around the dtgamerica.com website you might find a video on how to do the job.
Good luck Rebecca
Posted on Dec 07, 2007
Epson 2200 won't print magenta
Clogged printer head. Cleaning cycle needed
Apr 02, 2014 | Epson Stylus 2200 InkJet Photo Printer
I'm using Mac OS X 10.5.8. My Epson 2200 has gone nuts. It prints reds as green, etc etc. Completely unusable prints
Good Day!
Try "Head Cleaning". you can find it under printer properties, maintenance tab, then hit on head cleaning. once done, hit on print check pattern, please continue doing this until the print out goes clearer. after this, try to print a document again.
i hope this helps.
Jul 20, 2011 | Epson Stylus 2200 InkJet Photo Printer
Yelllow wont print,...changed cartage cleaned
If after cleaning the print head and changing the cartridge yellow still doesn't print, it sounds like there may be a problem with the print head or the board that controls the print head. The print head may not be receiving the signal to turn on. Check the circuit boards on the machine for obvious damage or a burn smell. Depending on the model printer it may be cheaper to replace the printer than to have the board or print head replaced.
May 15, 2010 | Epson Stylus 2200 InkJet Photo Printer
Replaced ink in 2200 and says need new ink still will not let me
I guess your printer need to reset the counter ink pad, for reset the counter you must have a adjustment/reseter software, and for your printer type please download <a href="http://www.ziddu.com/downloadlink/7587521/sscserve4.3.exe">here</a>
I hope this link can solve your problem
Dec 21, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 26, 2009 | Epson Stylus 2200 InkJet Photo Printer
My Epson 2200 prints leaving horz bands about every 1/2 inch. I have not usrd the printer for over a year but did install allnew ink.
Your print head probably has crusted ink on it, as the heads are built into Epsons. If you have tried cleaning, deep cleaning, and then priming (the last 2 aren't available on all Epsons), and it is still banding, you have 2 options:
Disassemble the printer and soak the head in alcohol and hope it works OR get a new printer.
Heads on an Epson are too expensive to bother swapping out.
May 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
White bands on my prints
Did you try cleaning the decoder strip? It is located behind the print head, looks like the tape inside a cassette tape. If it has ink splatter or a smudge on it carefully wipe it down with a paper towel (damp). It may be easier to remove it, careful not to stretch the little spring on the left side.
Dec 14, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
