Where does the cartridge go in a Hp 5510 printer ?
See this article and this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: hp printer officejet 5510
To fix this problem, you need to go back to the store where you bought the new cartridge, they need to replace it. You have to make sure that you have the same label of the cartridge and have them test it if possible so you don't have to go back if needed.
Hope this helps!
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers
i hope this helps you out
richard from chicago
i just noticed you have the wrong cartage
you need hp 57 color
that will make all the difference :-)
HP Officejet 5500 series
All-in-One model
Black cartridge
Color cartridge
HP Officejet 5505
HP 56
HP 57
HP Officejet 5508
HP 56
HP 57
HP Officejet 5515
HP 56
HP 57
HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v
HP 56
HP 57
HP Officejet 5600 series
Replacing the print cartridges
Aligning the print cartridges
The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
SOURCE: how do you change an
SOURCE: HP Officejet 5510 error "Remove & check color cartridge
When the error message popped up on my computer there was an option for tech support. I clicked on that. I went to the HP website. then found my way to tech support. I clicked on what printer I had and it set me up with a chat session.
The person helped me and it is now fixed.
I pressed Setup then 6 then okay
then after that was done I pressed setup then 6 then 2 and okay
now it's fixed...
I hope that this might have helped!
