Question about Microsoft Xbox 360 Console
Problems My x-box will no longer recognize my wireless controller or my memory card
  • chipndale Dec 03, 2007
    my xbox will not recognize my wirleless controllers. It will recogmize my remote controll. My friends xbox will not recognize my controllers. Nor will my xbox recognize his controllers???? dazed and confused
    President:
  • 4,402 Answers
Check the battery, un plug from system and or reboot
Posted on Dec 02, 2007
SOURCE:
Computer will not recognize memory card when inserted
Click Start, then type device manager in the Search box, then click Device Manager.
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete, restart your computer. Your USB controllers will automatically install.
Sep 20, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
Trouble With Internal Wireless Card/Wireless Assistant
open up control panel, go to network connections first..see if it's enabled
Apr 29, 2008 | HP Compaq Presario V6171CL Laptop
Im having problems with my plug and play and or autoplay, whenever I put in my memory card the options dont pop up but it is recognized.
There should be no problem if the options box does not pop up but the card is still recognized. However, if you want to see the options box, then follow the following procedure.
To fix this you will need to change your autoplay settings. If you are still running windows xp, then you need to go to microsoft and get this download. It is a program that will attempt to fix your autoplay settings. If you are running windows vista or windows 7, then you need to find your autoplay settings in the control panel to change your settings.
Mar 08, 2011 | Gateway GX7018E PC Desktop
Dual shock 3 controller will no longer stay synced to my system. When I turn on the PS3 I can press the Home button and four lights will flash but the control won't connect wirelessly. When I plug in the...
Have you recently tried using the controller for a different system.
If so, you will need to get a safety pin or something similar to press the little 'reset' button on the back of the controller. Once you press this button, connect the controller using the USB cable and you should be ok.
If this doesn't work, your wifi card has gone bad and will need to be replaced.
To check your wifi card, which controls everything wireless, try connecting your PS3 to wi fi. If you can connect then your card is good. If not, then you will need to have it replaced. Good luck.
Jan 20, 2011 | Sony Dual Shock 3 Controller for...
My Asus M50Vm notebook is no longer recognizing my wireless network. I have gone to the website and updated my drivers, but I still cannot connect wirelessly. I also checked to make sure the wireless...
I'm assuming by 'no longer recognizing my wireless network' that at one point in time your notebook was connecting without problem, but now for whatever reason it's not connecting because your Wireless Network (SSID) is not showing up when your notebook scans for networks.
If you remember what your Network's SSID is called, I would try setting your wifi card to connect to it manually vs connecting to 'any' SSID in the area. Wifi networks won't show up when you scan for them if they're set to not broadcast their SSID's.
That is the most mundane assumption I can make as to what's wrong. There are a bunch of other problems that could cause this, but I'd try this solution first.
Apr 22, 2010 | ASUS Wireless (90-c1i010-00xay)
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
Xbox rockband 360 wireless guitar
there is a small button between the 2nd memory card slot and controller inputs(where u plug in controller). Press and hold that button. If that doesn't work there is eitgher a problem with guitar or a connection interference with it.
Jul 01, 2008 | Microsoft Xbox 360 Console
USB Device not recognized
if the camera has memory cards (sD or xD or MMC) you can download pictures on the memory card then use a memory card reader with your PC to copy them. memory card readers are cheep and should do the job.
Jun 17, 2008 | Leica D-Lux Digital Camera
Controller/Memory Card
my recommendation is to return the unit, but there is a popular way that does in fact work. I tried it and my xbox lasted 4 week longer. Basically, wrap it in 2 towels, turn it on and leave it for 30 mins, come back , unwrap and reboot xbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Unusual situation - won't recognize rear USB, wireless controllers, or memory card
I had the same problem started yesterday. I stumbled accross this thread. This situation is not an issue with the controllers it is with the console. The solution that worked for me is turning the xbox on. Leaning it forward unplugging the power cable from the back while the console was running and then plugging back in and booting up. Everything working fine now. My bosses console had this similar issue too; we fixed it a similar way by doing the power loss reset, and then a couple days later it red ringed on him.
Aug 08, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
