Question about Belkin (F5D7231-4) Wireless Router
Belkin WirelessG Plus Mimo
Hi
ever since I bought the above it has been timing out but recently the problem has got noticeably worse, what can I do?
want change laptop as host and want my desktop to b the host i can only use 1 computer at time the 2 say unindentified network i have 2 laptops and 1 desktop computer desktop connected straight to router then to modem my laptop will work wireless if others not connected thas wrong
  • 556 Answers
Consider securing the wireless connection if you have not done so your neighbors MAY be able to utilize your wireless connection and your bandwidth if you do not.
see http://www.fixya.com/support/t281214-wireless_security
Secondly if I understand you you have 4 computers using the router to access the modem connected to your Internet Service Provider; three using wires and one using the wireless. First have youneed to confirm that your internet service provider allows multiple devices to share the connection (which is what your router is trying to do). If so do you have to logon / login to your ISP to access the internet? (This login may be hidden from you in the modem provided by the ISP) Research if it is required to have your router logon to the ISP instead of either one of the computers or the modem in order to support multiple users. If that is the case you will need to determine if your router is capable of performing the logon for you and configure the necessary devices appropriately.
I can possibly help with the above but will need to know your ISP, and the manufacturer and model for your router and wireless card(s) to assist in configuring the components. The manufacturer and model information will also provide a basis for securing the wireless network if desired.
Posted on Dec 06, 2007
SOURCE:
Bought an Belkin wireless g plus mimo router at
You maybe able to reset the router to the factory default by powering up the router, press and hold the RESET button at the back of the router for 7 secs..
Then open a browser and type in the IP configuration address to reconfigure the router.
Sep 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Usb network adapter adapter. I want to configure
If you ar eusing vista go to the small wireless indicator on your toolbar..dble click it then click connect to network...click on your connecion and it wil as you if you want to save it...probably similiar to XP
Jun 07, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need drivers for the belkin
have you checked the manufacture website
Jan 14, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I'm pretty certain that you can only have 1 host per computer/per name for a network. So, if you want to change the laptop as host you will have to setup a network under the settings. Create a network password along with the network name for that laptop. (Unidentified Network) is a correct network name. It's just that you probably didn't change it to a specific name that you wanted it to be in the box. after doing this, you should be able to go to the other computer's and try to log onto the network domain that you have created. after that in order to get approval to access the network domain you have to enter the encryption key which is the network password. you have to do this to all non hosted computers. after completion, you should be connected to that specific network.
Now you want you're desktop to be the host. Well, from above do the same steps for the desktop. But, instead of (in example) to lets say your laptops network name is (Home). Well, you would have to make the host name on the desktop to be (Home2). then set the encrption key. Then go to all non hosted computers including the laptop that you made the first network. because this is a new hosted network created by you're desktop and connect to that network and then supplying the encrption key to be able to access the network. and you should be good. Just my 2cents. although this may not work because you may have to have to routers to be able to create multiple networks but, like you mentioned earlier you have a wireless on you other laptop you can use the setup for that wireless to make another network. Hope this helps and good luck ;)
Dec 02, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Check all other wireless devices within the range of the router, cordless phones, cellular phones, etc.
Change the wireless channel on the router or possibly the other wireless devices.
2nd: check the Keep Alive setting in the router configuration if you have DSL. Set this accordingly
Nov 19, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7231-4) Wireless Router Logo
81 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
