Question about Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver
Local channel hd direct tv
Sound during an HD program on a direct tv dish signal will low every time change to commercial, happen only with local channels
  • 979 Answers
SOURCE: Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Posted on Oct 11, 2007
superminer
  • 26 Answers
SOURCE: Dimmer switch interference
i have seen this before you have back feed thru your lines somewhere there i no ground and it is reffeding through your equipment. honestly he techs were wright i wouldnt or any of my guys wouldnt touch it because u realy need a certified electrician to come ou and find the problem andfix it before it runs your slimline dish and eciever. The switch u installed u did run all four 4 wires from he dish to the switch didnt you. Check all lines of coax but if u didnt run all four 4 lines then u will have problems. I still think u need an electrician.
Good luck,
Please rate
Posted on Jan 13, 2008
b_stro804
  • 68 Answers
SOURCE: hughes sd-dvr80 direct tv receiver tivo
go to your settings page and run the initial setup. make sure each section is done correctly. the tivo might take a second to start downloading the locals.
Posted on Jan 04, 2009
  • 56 Answers
SOURCE: Need to Frequently Reset Dish Network HD VIP 612 Solo DVR.
When you bring up your guide look at the top of the screen and you will see the LIST: if this says ALL HD then press the guide button until you see ALL SUB or a menu and select ALL SUB. If your guide keeps changing by itself its possible to have remote interfence since you have a UHF remote, especially if you also see channel changes as well. Try setting the guide and go from there. If you still continue to have issues call 1-800-333-3474 for tech support for extensive troubleshooting or at dishnetwork .com/tech.
Posted on Dec 02, 2009
SOURCE: My Hd channels are saying complete signal loss
Hi edhayes27 my name is Mike Houston of DISH Network Executive Office. This posting in FixYa shows you have the 311 receiver; this receiver will only show SD channels. We do have the VIP 211 which will show in HD and SD channels. If possible can you verify the model number of your receiver, which indicates you
Posted on Jan 12, 2011
I just switched to an HD receiver. The sound on the HD Channels is lower than the sound on the regular channels. How can I fix this? Dishnetwork has aready checked their end.
Some Sanyo TV's have a feature called Dynamic volume, this feature can be enabled by just pressing the dynamic volume button on the factory remote. We happen to offer a similar feature called volume leveling on our VIP 722k, 612, and 222k receivers. This is a recently released feature that will keep the volume even, during commercials or when changing channels. To access this press menu 6-1-6 and select enable under volume leveling.
Daniel Busa
DISH Network
Customer Service
Oct 03, 2010 | Sanyo DP37647 37 in. LCD TV
Magnavox 52 inch HD Tv connected to a Dish Network HD Satellite Box. If you watch a channel with HD programming and then tune to a analog channel there is no sound. The tv has to be turned off and back...
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
best of luck- JD
Nov 18, 2009 | Philips Televison & Video
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Oct 11, 2007 | Televison & Video
Channel changing by itself.
I will tell you that westinghouse is the worst company among other brands. If you have warranty, return it and buy a sony or panasonic with a little extra money. It will help you later from buying another TV that is also as crappy as westinghouse's.
Oct 01, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Signal from HD cable box occasionally gets scrambled/black out
Try removing 1080i from your list of available video resolutions in the setup screen of the Plasma display. If you are using a HD satellite receiver, check the LEDs on the front and note if the device is slipping into 1080 mode when the probem occurs.
Jul 11, 2006 | Philips E-Box FTR9965 DTV Receiver
Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver Logo
97 people viewed this question
Top Hughes Televison & Video Experts
Steve Allison
Steve Allison
jason
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
