Question about Maytag MZD2766GES Side by Side Refrigerator
Door problem Main compartment door will not close unless you push it closed. How do I fix the hinges to make it close easier
  • 89 Answers
A very VERY hard job to do. Door has to come off and washers inserted or taken away.
Posted on Dec 16, 2007
SOURCE:
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Freezer seal
Good day,
The first step is to make sure the machine is leveled properly.
It should not be allowed to lean to the left. As well, the adjusters should be set, so there is a slight tilt to the rear, so the doors have a tendency to close on their own.
The freezer gasket should be cleaned, as well as the frame it makes contact with.
The reason this happens is a lot of air is pushed into the machine when the main door is closed. There are 2 openings between the main compartment and the freezer, so the air is forced into the freezer compartment, wanting to push it open.
If the gasket on the freezer fits well, then the problem, is the gasket's magnets have become weak.
The repair is replacing the gasket. However, many people find ways to use the machine by adjusting their habits to ensure the door closes. One example is to keep a hand on the freezer door when closing the main door, or, closing the fridge door slower.
In any case it's your decision as to what you want to do.
Feb 09, 2010 | Kenmore Refrigerators
Right side door does not close unless you push it closed with your hand
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on.
Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
Main door doesn't close easily
You may well need to purchase those bottom end parts to correct your problem. But first.....
Spray the door gasket on the hinge side with a food compatible
silicon spray. (makes it slippery).
Remove the heavy items from the door, and loosen the screws on the top hinge and try to adjust the door for a better fit.
Nov 03, 2009 | Kenmore Refrigerators
Right side door pops open when left door is closed
Is this a new unit? This is caused by air rushing into the other compartment through a damper control. Most mfr's. install an air check valve at the bottom of both doors that will pop up to let external in, thus alleviating door blow out.
Apply a food grade silicone to the face of the door seals to add tackiness to to the surface. Follow link to purchase.
https://www.repairclinic.com/PartDetail/Silicone-Lubricant/WP99003172/1074750. A suitable substitute would be a little Vaseline.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 11, 2017 | KitchenAid Architect KBFA25ERSS Stainless...
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Maytag MZD2766GES Side by Side Refrigerator Logo
107 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
