What has happen is your drain line has become plugged with either rice or corn. Remove the drain line at the pump, you will also have to remove the hard line from the pump is self, (you will need a set of pliers to do so.) In side the hard line you will find a diaphragm with the cal pert to your problem, remove the blockage, check o-rings on the hard line to ensure that there is no cracks or breaks to prevent leaks. Tighten hard line back into the pump, and replace the drain line. Hopefully this helps you out.
small green liight beside heated dry is on and no other buttons will work. the light is a small...
(More)
SMALL GREEN LIIGHT BESIDE HEATED DRY IS ON AND NO OTHER BUTTONS WILL WORK. THE LIGHT IS A SMALL CIRCLE WITH A 1 ON IT. WHAT DOES THIS MEAN? I HAVE OWNED THE DISHWASHER ABOUT 3 YEARS AND NEVER NOTIECED THIS LIGHT. I THOUGHT MABE ONE OF MY CHILDREN HAD PUSHED THE DELAY BUTTON SINCE I HAVE NEVER USED THE DELAY BUT I CANT GET IT TO CANCELL OR NOTHING I EVEN TRYED UNPLUGING IT.
i have a conversion kit for the westinghouse sb907, when i moved i lost the part that goes on the...
(More)
i have a conversion kit for the westinghouse sb907, when i moved i lost the part that goes on the tap. is there a part number for this?
