Question about Rockford Fosgate Punch P2002 Car Audio Amplifier
James tryin to set and fo freq and gain whats the est settings for p2002 and a runningkicker cvr 12s
  • 33 Answers
Do you have the amp bridged first off? if you do unbridge it. Next,
1) Turn all the settings all the way down on the amp.
2) Turn your bass on the radio into the negatives (-2 or-3)
3) Turn the volume up to the point where your highs start to not sound good, then turn them down just enough to where they sound good again.
4) Turn your crossover to about half if your box is ported, or three Fiths if its sealed.
5) Raise your gain slowly untill either the volume doesn't get any higher or you hear the subs start to sound funny. Now turn it down just a hair.
6) Turn your crossover up a hair then down a hair and see what happens, if it gets a touch louder with out distortion then leave it. If it losses clarity then place it back to where it was.
7) Listen to a couple songs you know well and stand in front of your subs at volume to be sure theres no distortion.
You should be good at this point let me know if you need something else.
Posted on Dec 05, 2007
RF p2d2 12 smoking
you cooked the coil in the sub when you see smoke you have clipped the sub. improper wiring probably the issue ohms must match gain must be set properly . if you had gain all the way up thats what did it.
Jun 20, 2013 | Rockford Fosgate Car Audio & Video
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
I cant get my jl audio w6 10s to give off much bass with the jl audio 500/1 amp
here is a manual for your subwoofers: http://mobile.jlaudio.com/pdfs/8-12W6_BDS.pdf
use the wiring diagram for 1.5? (1.5ohm) with 2 speakers. the diagram for 3 speakers will not work, because it would bring the load down to 1 ohm, and the amp cannot go below 1.5 ohm.
to set up the amp:
under "preamp output section", on the "output mode" switch, select "amp filter"
to set up the levels: start with the amp gain pretty far down- with the input voltage on low for line level outputs from the deck, and on high for speaker outputs from the deck. now turn your cd deck as far up as it will go until it distorts, then turn the cd deck down to just where it stops distorting. now, you can start to turn up the gain on the amp.
on the filters, youll prolly want the cutoff filter around 100hz @ 24db slope. start with the infrasonic filters off, but, if you do get into them, try centering between 30 and 60hz on either, and, possibly dropping the cutoff filter to 80hz.
Jan 31, 2011 | Jl Audio 500/1 Car Audio Amplifier
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
How to set gains, brand new amps dont kno much about car audio.. how do i tune my amp for loud bass
for loud bass is 120Hz the freq. and adjust the audio gain in scale 1 to 10 in 7.
Apr 24, 2010 | Hifonics XXV Sampson Car Amp
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
Amp settings
It's going to be mainly "what sounds best", but I'll give you a start.
  • Set the gain to 50%.
  • Set the LP filter to 12db at about 80Hz.
  • Set the infrasonic filter to ON and at about 20Hz.
  • Set the Bass EQ to ON, Q to 0.7, center freq to 40Hz, and boost to about 5dB.
The other settings are going to be based on how the system is connected to the head unit.
Mar 22, 2008 | Jl Audio 500/1 Car Audio Amplifier
Rockford Fosgate Punch P2002 Car Audio Amplifier Logo
110 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
