Question about Polaroid I533P Digital Camera
Makes 3 beeping sounds then turns off
My polaroid i533 makes three beeping noises then turns off...what do i do
  • 5 more comments
  • jai boogie Dec 03, 2007
    I have a polaroid i533 and i would turn my camera on and it makes 3 beeping noises then shuts off. Now it wont turn on at all.
  • NickNayme Dec 30, 2007
    I have the exact problem with this model. I don't have a different card to try in it, but I tried it with the card OUT and it does the same thing.
  • albsure Mar 30, 2008
    TRY REMOVE AND REPLACE BATTERY
  • Anonymous Apr 19, 2009
    i have tryed everything but i cannot get the lens in.
  • Anonymous May 02, 2009
    My Camera lens was crooked, but somehow it evened out, so now its still stuck out, but not crooked. It beeps three times & doesnt do anything.
  • mditzler May 06, 2009
    makes 3 beeping sounds then turns off
  • Anonymous Mar 12, 2014
    camera will not turn on and makes 3 beeping noises.
    Problem Solver:
  • 7 Answers
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Posted on Feb 10, 2008
    President:
  • 4,402 Answers
What happen if you put another memory card in it?
Posted on Dec 02, 2007
I533 polaroid camera beeps and turns off
There are a couple of possibilities here:
i'm assuming that this camera uses a SD memory card. You have most likely bought yourself an SDHC card. The cards will look exactly the same, except for their name. SD cards only go up to 2GB, while SDHC's go much higher....sometimes the SDHC card will cause camera's to do this because it is not supported.
the other possibility is that you have a defective battery and it doesn't hold a charge. You could test this with a digital multi meter.
the last possibility is that there in internal damage/falty wiring
hope this helps,
Thomas
Feb 28, 2010 | Polaroid I533P Digital Camera
My son dropped it now it wont open turn it on it beeps three times and shuts off
Unfortunately, with Polaroid cameras, if you hear (3) beeps and it will not power on; this means INTERNAL FAILURE and it's unable to be repaired.
Oct 05, 2009 | Polaroid i733LP Digital Camera
Not turning on, light blinks once that's it
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Polaroid I533P Digital Camera
Polaroid camera i533
well sure u just go to
Chandrakanth
+(91)-9346340947,9392416633
1-8-3/23/7 1st Floor, Hotel Sunanda, Chikkadpally, Hyderabad - 500020
Oct 24, 2008 | Polaroid I533P Digital Camera
My Polaroid i533 digicam won't turn on
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
Aug 14, 2008 | Polaroid I533P Digital Camera
Is the polaroid i533 camera compatible with sdhc memory cards? Or does it only use sd memory cards?
No, the polaroid i533 camera is not compatible with sdhc memory cards. Use only SD cards.
Jun 27, 2008 | Cameras
I533
Unfortunately your camera needs to be sent in for service. I have had to send in a camera for service to kodak make sure you stay on their tale and don't take any guff from them. Make sure they have all the information right. If this is not the answer you are looking for please disregard but this is most surely the only solution.
Good luck,
lee
Apr 14, 2008 | Polaroid I533P Digital Camera
Polaroid i533 digital camera
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Jan 03, 2008 | Polaroid I533P Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
416 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
