Question about Philips Magnavox 51MP392H Rear Projection Television
Phillips Projection TV
We have a 60" Phillips Projection TV. When I turn ithe TV on the "on" button comes on (red) and when I turn on the stereo surround sound the sound plays through there, however there is no picture and no sound coming from the TV. It hooks through the DVD player into the Satellite receiver. The TV in our other rooms work fine, satellite fine, etc. Any thoughts on what is going on?
  • susannoce Dec 03, 2007
    I checked everything you said....connection is the same as it has always been and has worked for the past two/three years so I am going to assume it is correctly hooked up. I don't really see another way to hook it up (but then I wouldn't know). We put a movie in the DVD player and nothing happened. Tried to bring up the menu and nothing happened.
    We have Dish Network with the DVR option. We also have a stereo. And we have a DVD/VCR player. The tv plugs into the DVD player. The DVD player goes into the satellite receiver. Stereo hooks into the TV directly.
    So.....still no picture or sound coming from the TV.....HELP ME !!!
    President:
  • 4,402 Answers
Make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Posted on Dec 02, 2007
  • Cary Farah
    Cary Farah Dec 03, 2007
    connect the dvd directly to the tv and see if you get picture
    of course put a dvd in and push play
Can not get my surround sound system to work with Sharp LC-40F22E using usual audio cable, sound still comes through the tv speakers and can not find how to turn tv speakers of or tell the tv to use...
The way to turn off the tv speakers is to press the menu button scroll to the option category navigate to output select and choose variable. However just turning off the tv speakers will not cause the surround sound system to work with this television. Connecting the red and white composite audio cables to the television's OUTPUT will get you stereo sound. Some people opt to keep the tv's speakers turned on when doing this. In order to get the digital optical out to work between the television and the surround sound system you will have to be using input tv. You will have to be using the television's tuner with digital cable no cable box or with an over the air antenna. Did you make sure you connected the red and white cable to the surround sound aux or any composite input and choose the right function on it?
Dec 03, 2010 | Sharp Televison & Video
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
On our Phillips 60" rear projection tv, the sound doesn't come on, but when you push the volumn on the tv itself, the volumn will come on and increase or decrease until you let go. - What do you think we...
I know this fault from an older Grundig TV,maybe the sollution is the same.There is an reset switch build in the powerswitch wich can cause this problem.Replace the complete powerswitch.
Aug 13, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen is round on top & bottom ithe face looks like 2 sets of eyes the wods are red & blue
did you bump in to your tv?
your lamps are probably out of adjustment
some tv's have a "magic focus" button that automaticly adjust your lamps
check your tv setup
Jun 26, 2009 | Philips 60PP9202 60" Rear Projection...
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Contact us at www.TvRepairKits.com. We are working on solving this problem as we speak.
Nov 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
No sound when using dish or regular tv
This may be old news but just in case ...
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
Feb 24, 2008 | Audio Players & Recorders
No sound
check your remote to see if it's on mute...or mute is enabled...check your connections from the tv to the cable box...if your using surround sound...check those connections as well...if you have a dvd player..hook it up to the tv and see if you get audio...let me know if this helps...if not i will give you more things to check
Feb 07, 2008 | Philips 60P8341 60" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
