Question about Hitachi 55HDT51 55 in. HD-Ready Plasma Television
My Plasma 42PD580DTA
When I watch DVD on S-video or composite video the picture is in Black and white. When I watch tv channels the picture is colour. I tried the DVD player in another TV and the DVDs are colour. so I feel there is a problem with the Plasma.
  • skygirl Dec 02, 2007
    I used the same lead when I plugged it into my old TV and it worked fine. So maybe it is the TV.
  • skygirl Dec 03, 2007
    Problem solved! I lent over to see behind the TV and accidentally pressed to main switch to turn off the Tv. When I turned the Tv back on the problem had fixed itself..Maybe a restore process or something. thanks anyway..
    Scholar:
  • 43 Answers
I assume your DVD is coming up in colour when you plug it into a standard scart connector? Have you tried using a different S-Video cable because this sound symptomatic of a dodgy lead?
Check the SCART end of your lead for any bent or broken pins.
Failing that if the problem lies with the TV itself I'd really recommend having a pro look at it. Plasma's are expensive and opening it up if you don't know what you are doing is a bad idea.
Posted on Dec 02, 2007
  • jonpitans Dec 03, 2007
    I think its lore likely you nudged the scart lead while you were doing that. My old PS2 did the same thing and you had to jiggle the SCART lead until it went colour.
    Anyway, glad you got it working.
SOURCE:
My I got sound but no picture on my DVD player
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
Sep 03, 2012 | KLH DVD8350 DVD Player
How to connect a DVD player and watch a movie on a EWF2004 ?
on the front and on the back of the TV it has a set of tulip jacks a yellow one for
video and either a white or red one for audio. Take a set of RCA cables and hook them
from the DVD to the TV via the colors yellow for video red/white for sound. For this TV
I believe you will need to go throught the channels until you find composite/AUX1 or composite/AUX2 which the DVD will be assigned to. If the DVD player is on and functioning you should get a picture. If you dont get a picture and you get fuzz and buzzing on these channels you have the video and sound reversed. Some models may have a source button on the front of the TV or on the remote. If this is the case use the source button to get to the Composite/AUX channel.
May 06, 2011 | Emerson EWF2004 20" TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
When i connect the DVD or Playstation to the AV of the HITACHI plasma ( model 42pd580dta ) I get a fickering black n white screen, no sound, you can just see the dvd or ps screen..Its like its not tuned...
Unplug foxtel three video pins cable and plug yellow video cable of dvd then play it, you will get correct and clear picture in video input.
You can not plug composite and component video at same time in video input of tv, that is cause of your problem.
Thanks
Jul 31, 2010 | Televison & Video
When i hook up dvd player to a insignia plasma tv i get a picture & sound but it is in black&white.how do i get to be color
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Oct 23, 2009 | Insignia 42" Flat-Panel Plasma HDTV
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
Mar 27, 2008 | Disney Princess TV/DVD Combo
RCA CTC203 No Colour in the Video IN or Svideo but colour is present on tv channels.
try removing your vcr and dvd connections first while watching TV programs alone!. if still there are no colors then your tv have a problem!
Dec 05, 2007 | Televison & Video
Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Dec 02, 2007 | Televison & Video
Hitachi 55HDT51 55 in. HD-Ready Plasma Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
