Question about HP All-in-One Printer
Deskjet printer problem -paper jam still remains on the coputer mode.
How do i clear the word paper jam on my printer mode on the computer when there is no longer a paper jam. Does it take some time to clear on its own?
  • 2 more comments
  • Anonymous Feb 23, 2008
    printer not working saying paper is still jammed.paper has been removed and cleared.   I eliminated the paper from the machine. no pulling or tugginh
    I have gently removed the paper and nothing is now blocking the paper avenue
  • Anonymous Jan 26, 2009
    my printer has many documents but they wont print
  • Tony smith Apr 01, 2009
    I have a paper jam error message which I can't clear, I tryed turning the printer off and on, unplugging it, I pulled the cover off the back, no paper is jammed in the rollers. when I power on the printer, it will print a test page OK. But it will not print any documents, due to this error message.
    (It has been working find up to this point)
    Help!!!
    President:
  • 4,402 Answers
If you have removed the paper and any paper that might have come off then turn the printer off and then back on to reset it, if that doesn't work, unplug it and plug it back in if that still doesn't fix it you have a loose piece inside yet.
Posted on Dec 02, 2007
Printer is not working not printing
Posted on Dec 18, 2007
SOURCE:
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
I had a paper jam- I pulled out the paper - checked every where, all paper was cleared. I can make copies but can't print anything from the computer. Status of the printer says paper jam, but there isn't...
open ur printer front cover clean paper pickup roller (black rubber roller)
2.:- then go to printer back cover open clean all (black rubber roller)
hope this is working
Apr 08, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Had a paper jam, now printer will not work. how do i get it to go again?
clear the jammed bits by removing back strap from ur printer. Now u need to see if any bits of paper has remained on the far right of the cartridges. Plug power, open cartridges cover & use a torch to see if any paper remains. Unplug power without switching off & clean any bits left. right
Feb 06, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet d2360 paper jam
dear sir
I miss my Driver CD so I want this Deskjet D2360 Driver
Jan 19, 2009 | HP Deskjet D2360 InkJet Printer
Paper jam
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
Oct 06, 2008 | HP DeskJet F380 All-In-One Printer
my printer can't start a message appear : one of the composants may be expired
Dec 29, 2007 | Computers & Internet
Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Oct 29, 2007 | HP DeskJet 960c InkJet Printer
HP All-in-One Printer Logo
88 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
