Question about Logitech X-530 Computer Speakers
Speakers have no sound
I plugged them in and there is no sound. When I plug them in half way I just get a buzzing sound
  • Chris Cobb Dec 16, 2007
    the computer died we reinstalled everything on the comuter the speakers are hooked up right but when you go to sound settings it says nothing is hooked up
    no sound what so ever boss!
    President:
  • 4,402 Answers
The buzzing sound is normal for half way, however it does tell you the speakers work, First thing is to make sure the mute is not on.next make sure you have it plug into the out put just and not the mic or input.
Posted on Dec 02, 2007
I have a Dell W3706MH tv monitor and the sound just stop working. I unplugged the speakers and plugged them back in still no sound. I unplugged them because it was making a loud buzzing and popping noise...
If possible, plug the speakers into a portable device such as a cell phone, portable cd player or a tv that is equipped with a headphone jack (if speakers have the jack). If not, if the speakers have the red and white, ref and black or black and white male end connectors, plug them into a tv or dvd\blue ray player. If you get sound they are good, and you need to adjust your sound options on your computer. Let me know if this helps\works. Also, not all speakers are compatible with all computers and must have the same sound level equivalence to the device they are being used with. i.e. Ohms etc.
Aug 29, 2014 | Televison & Video
There is always a buzzing sound come from my spekaers when i pluged in computer
Try to attach your speakers to another device, DVD player, Amp., Receiver, etc. and if the buzz is not there; then you know the problem is with the computer. Check the inputs and be certain they are clean and make perfect contact with the plug ends. If contact is positive; and the sound still has a buzz; you are experiencing line noise that requires a software fix. Down load Divx or some other application and see if that works without distortion? Match up the color of the plugs to the color of the input on the sound section of your computer. If they are incoorect, you can experience a problem there as well.
Dec 18, 2013 | Audio Players & Recorders
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
Loud buzzing, but no sound
Sounds like they are plugged into the wrong port on your computer? You need to make sure they are plugged into the Green ringed port on your sound card.
Hope this helps
Cheers
Al
Sep 11, 2009 | Bose Audio Players & Recorders
There's always a bzzz sound coming out when plugged in.
if there's buzzing coming out, there's probably a rip in the actual speakers. Something is torn on the inside thus the weird buzzing noise.
Unless it was a zzzzzzzzz...... noise then there's probably some sort of interference. Possibly cellphone close by, or some other magnetic thing to create that annoying sound.
Apr 21, 2009 | Creative Labs SBS-260 Computer Speakers
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Feb 19, 2008 | Logitech S200 Computer Speakers
Lots of problems please help!
  1. firstly you check the cable loose/break,
  2. check it by using multimeter
  3. dry soldering, loose contact
  4. resolder soldering points or reconnect cable
  5. your powersupply transformer coil may breaked now it become loose contact.
  6. you check the supply output voltage with and without load
  7. if low or no output voltage replace supply
  8. if you don't get the proper transformer rewind it
  9. also check power amplifier section short ckt
Jan 17, 2008 | Cyber Acoustics CA-3550 Computer Speakers
Rear speaker buzz!!!!!!!!!!!!!!!
i had the exact same problem which eventually spread to all speakers i took it to local repair guy, he was able to resolder the power board seem to fix all didn't really cost me much cheaper thean shipping back to spherex or whoever
Sep 30, 2007 | Spherex Xbox 5.1 Surround Sound System...
Logitech X-530 Computer Speakers Logo
125 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
