Question about Whirlpool LHW0050PQ Front Load Washer
Spinning Although it is level and not moving at all, the drum seems to be rubbing on something.  It sounds like the breaks are on.
  • Betrayedgirl Dec 29, 2007
    Whirlpool LHW0050PQ front load washer is making more pronounced noises slapping/banging noise during spin cycle.
Thank you, the belt was to loose and Whirlpool has replaced it. They actually changed the material they are using for the belt. Hopefully now it will not get worn out so fast.
Posted on Mar 04, 2008
    Genius:
  • 1,554 Answers
You may have some clothing or such under the drum ,
pull back the rubber lip and look under tub.
or the drum bearing is going bad.
does it turn easily .
I have whirlpool lsq9110pw2 washing machine. During the spin cycle, there is a clicking sound, and eventually you can smell and see smoke. I have replaced the motor couplings and it still does the same...
When it is spinning open the lid and see if the spinning stops or if it is relational to the spinning of the drum. It sounds like either the clutch is bad or the brake shoes are rubbing or maybe something is stuck between the drum and the tank wall.
Oct 17, 2014 | Washing Machines
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG wm2016cw smells when spinning fast. I opened the top but do not visually see any damage or smell it. When I open the door, I can smell something was rubbing. Took off the door gasket and it seems fine....
It sounds as though the drum may have dropped slightly and is rubbing against the seal. This normally occurs when either the top springs have stretched slightly (visually it's not noticeable) or the bearings are worn. Hopefully it's the former, as the springs are replaceable at little cost and can be done as a DIY project. The best way to see if it is the drum, is to close the door and look through the door window. The drum should appear central to the window. There will be online guides on how to change your particular model springs, as they are all slightly different. The only other possibility is that the drive belt at the rear of the machine is wearing out, or rubbing against something.
Dec 04, 2017 | Washing Machines
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
I have a Kenmore HT4 front washer and it washer is making a loud noise when it is in the spinning cycle. It sounds like the inside cycle is hitting up against something. It seem to wash okay and we...
There is only two things that I can think of 1: The bearings are going or 2: something has got under the door seal and is in between the metal drum and the plastic cover (around the drum). Could be something like a coin or even a bra wire.
Jul 28, 2011 | Kenmore Elite 45986 Front Load Washer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
AEG LAVAMAT W1450 SOMETHING LOOSE IN DRUM WHEN SPINNING
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
