Question about Insignia IS-DVD1001 DVD Recorder/VCR
DVD's won't play
Music CD's and Picture CD's work fine. I put in a DVD and it says NO DISC.
    Genius:
  • 1,003 Answers
Have the laser lens assy and drive hub cleaned AT TV REPAIR OR ELECTRONIC SHOP
WHAT CAUSES THIS PROBLEM IS DUST AN LINT BUILD UP ON THE SURFACE OF THE LASER LENS AND DRIVE HUB
Posted on Feb 02, 2008
SOURCE:
DVD player freezes during playing
Open the tray and use a smooth cloth with rubbing alcohol on it.
Jun 10, 2017 | Magnavox Televison & Video
Cant play computer disks such as pictures
Computer disc are written in a format that PS3's read, if you want to play photos or what not you need to burn your disc using like Nero or Power DVD to say the least, you need to select picture CD not DATA or otherwise.
If your doing music you need to burn using make music CD not just drag and drop.
Try burning using picture CD format then update me with any questions you may have or problems that may arise from this solution.
Hint!
If you got a SD CARD you can put the photos on it and the ps3 will pick those up just fine!
Let me know how it works out.
Thanks
Ed aka rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Dvd-audio cd burning issue
If you are burning a "Data Disc" (the burning software should tell you or have you select it) then music will NOT work on a CD-player. It will only work in another PC.
Data disc is for files, pictures, videos, music that you want other COMPUTERS to be able to read and play.
If you want a music CD to work in a car or something like that it NEEDS to be burned as a music disc, not data.
Hope that helps.
Mar 17, 2009 | Gateway GT5056 PC Desktop
NO DISC message
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Insignia IS-DVD1001 DVD Recorder/VCR Logo
60 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
