Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Plasma Tv 42PD580DTA, Black and white scr...
By skygirl on Dec 02, 2007
The colour is fine while on tv channels but when changed to watch a dvd the colour goes Black and white, when I stop DVD the screen picture rolls
Same Problem
Feb 25, 2009
-   I seem to have the same problem, DTT/TV is fine, same with COMPOSITE, and HDMI, but when i change it to COMPOSITE, the picture changes to black and white, rolls and changes input to NTSC from PAL. As far as I can find out..there is no way to change the COMPOSITE colour scheme from PAL to NTSC and vice versa, so its doing it itself. This is a pain in *** as I have the foxtel conected to it this way and i cant watch it now :(-   jonco
Jan 07, 2009
-   Mine is a new Panasonic 42 inch tv and an old dvd player. Was working when originally set up, but now is black and white. Did have black and white also on tv once, but was loose cable. Tightened (monster) cable and seemed fixed. At least it was on the tv, I guess I didn't check the dvd til now. Did I get a bad cable? (The cable doesn't tighten on one end as well as the other)
-   Guest
Dec 27, 2008
-   tv is black and will only work on imput 55hds69 -   first call
Dec 01, 2008
-   Yes, same problem when we changed from hitachi to panasonic DVD player-   cisecon
Apr 16, 2008
-   Changing from Component or Composite input back to DTT/TV and it automatically changes my main signal from PAL to NTSC and this brings about the black and white and rolling picture. Even though I reset the channels back to the PAL signal, once you try and watch a DVD or video, it changes back to the NTSC format. Still no luck with an answer from Hitachi yet!!!-   yakswright
Solution #1
posted on Apr 28, 2008
Somewhat Helpful)
Davem04
Rank: Apprentice
Rating: 70%, 1 votes
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Was this helpful?
Yes
No
Solution #2
posted on Mar 22, 2009
Not Rated)
greg1122
Rank: Apprentice
Rating: 0%, 0 votes
I am no expert so my terminoligy is not perfect. I just bought VIZO 42". DVD player was playin in black and white.. I ended up getting it to work with color and sound by hooking it up as "AV" not "COMPONENT" and using a S-Video Cable along with the RED,WHITE,YELLOW cables also.Now, this is hooking directly from DVD to the TV. I dont have it going through the directtv receiver. It works the way i have it, so i aint pushing it.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Is the Apex ld4088 a realiable set?
Answer
trying to find ot who makes vivo plasmas
Answer
it has an f onscreen all the time and the remote will not work
Answer
lcd tv fell and part of the screen is shattered (inside- the outside screen is still in 1 piece but... (More)
Answer
i have a ultravision plasma tv model # 55hdt52 with a broken screen. Where can i find a new screen... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
