Question about Sony SPP 933 Cordless Phone
Sonny SPP-933 manaul does not have any instructions for setting the time on the answering machine
I can't figure out how to set the current time on the phome, so that answering machine messages give the correct time of teh call.
4 Suggested Answers
  • 3 Answers
SOURCE: Answer Machine
Here is the link for manual
Posted on Jan 01, 2009
  • 50 Answers
SOURCE: help me set the time on sony spp aq600 PLEASE
Here is a link to the user manual...
Hope that helps.... Tripp
Posted on Jan 05, 2009
  • 2992 Answers
You can find the user manual at Sony's site here. Click on the link under "Manuals".
Posted on May 12, 2009
  • 3 Answers
SOURCE: spp n1000
1.Press PGM. The Talk/Batt Low lamp flashes.
2. Press SPEED DIAL.
3. Press one of the dialing keys (0-9) to store phone number. You will hear confirmation beep.
4. Enter the phone number you want to store (up to 20 digits)
5. Press PGM. You will hear a long confirmation beep and number is stored. Tall/Batt Low lamp goes off.
Do not allow more than 20 between each step of the procedure. If you enter a wrong number, press PGM and start over.
Posted on Apr 16, 2010
0 characters
1 Points
Cannot activate the answering machine part of the phone
Contact your carrier for assistance in setting this up.
Apr 23, 2014 | Sony SPP A946 Cordless Phone
Sony spp a967 antenna is broken
Mar 23, 2013 | Sony Phones
Bought a sony 900 mhz ssp-933 cordless ph from yard sale. it's messages are full, how do i erase? thanks
should be able to delete meassages right from handset push middle buttons follow prompts
Jul 14, 2011 | Sony SPP 933 Cordless Phone
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
Manual for an older model Sony telephone/answering machine system
Jun 16, 2010 | Sony SPP A700 Cordless Phone (SPP-A700)
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Phones
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Phones
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
Sony SPP 933 Cordless Phone Logo
Top Sony Phones Experts
Are you a Sony Phone Expert? Answer questions, earn points and help others
