Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave Door Switch Problem?
I have a GE Spacemaker XL microwave, model #J VM13398W002.
When the microwave door is closed, the unit will not start cooking (all display lights and timer are operating fine). When the door is lifted up by the handle while closed it will sometimes start cooking, but when the handle is released it will stop again. I'm sure it's a door lever or monitor switch, but I'm not sure which one is most likely to be the problem (upper lever switch, lower lever switch, cam switch, monitor switch, or the top secondary door switch). I doubt it's a thermostat switch.
  • jokenart Apr 15, 2009
    kjkjksjdkjsdKSJDKjsd
  • GE Master
  • 9,100 Answers
That model number has too many digits after the JVM. Could it be JVM1339BW02 or JVM1339BW002?
If one is bad, it's probably the bottom switch, whose wiring goes back to the power relay, thermostat, or fuse, depending on eact model.
The switch with thin wires going to a ltitle connector on the board is the door sense switch. That's not likely your culprit.
I usually recommend you replace them all while you're at it.
It sounds like it may actually be a loose or misaligned door or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
GE models have a very helpful "mini-manual" hidden inside the unit behind the control panel. Handy in troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
Need to insatall new relay switch on microwave have switch but unplugged all the other switches and dont know where they go
Posted on Sep 18, 2009
GE XL 1400 Spacemaker Microwave
Clean all the visibility of the microvave which causes the light switch logged. pls consult the user manual in cleaning the oven.
may help, melnavz
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
GE Spacemaker XL - fan stopped working, light will come on and timer will count down.
either the magnatron fried , or the fuse fried... either way the microwve has to be taken down and opened up.
If you have the serial number , GE will send you a replacement magnatron (but will not service the unit for you).
contact GE and they will take care of you... the magnatrons are warranted for like 10 years....
Mar 23, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker XL microwave oven blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the house fuse or breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | GE Profile Spacemaker XL 1800 36 in....
My microwave won't heat
The real clue here is strangely enough the table not turning.
All units have a switch in the side (usually the right side) of the cabinet--when door is opened it allows the unit to work but will not heat or the table (usually both) will not work.
It has to be got at from the inside of the unit--little plastic holder with the switch which looks like a leaf switch.
What I have seen several times (including a unit I own) is that from countless opening and closing the door the holder may break or even melt and the contacts on the switch no longer are in position to work when door is open.
The purpose of such a switch is simple---it prevents the unit from being used if the door is OPEN.
Not a hard or expensive repair
Dec 06, 2012 | GE Profile Spacemaker XL 1800 36"...
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
3,134 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
