Question about Raymarine RL70CRC GPS Receiver
Display After working fine a few weeks ago, now the display shows only a thin pie wedge shape directly aft. If I turn the raydome, the wedge stills stays aft, as if not related. I reset to factory defaults, no luck. any ideas?
  • 16 Answers
It sounds to me like there might be a video processing problem in the scanner radome, or a break in the interconnect cable that runs from your screen to the radome.
If you did any work onboard recently that might have disturbed the interconnect cable please revisit the scene. If there was any kind of splice in the cable something may have come loose.
If the normal checks of tight, clean connections, adequate power to the display (which feeds the radome) don't revel anything, you may wish to call Raymarine or a local service dealer.
Posted on Dec 28, 2007
Have a cadi cts 03 and my radio display when out cd still works and I check all fuses and there fine what could it be?
If the cd still works then it is just a bad display in the unit , replacing the unit would be cheaper than repairing it.
Nov 02, 2014 | Cadillac CTS Cars & Trucks
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
Why is it that in the last 2 weeks, sometimes the car starter works and sometimes it doesn't?? It cant be the battery cuz it shows a green light PLUS I tried using my 2nd one (extra remote) and I have the...
the problem sounds like it is how the starter works. It starts and afte a few seconds it does a system check to see if the car started and if works right it will continue to leave the car on and if not it trys 2 more times to start and stay on. Most techs use voltage sense or a virtual tach signal to do the system check. I have found that the best way to have the starter work and stay on is by hooking up the tach signal and making sure the options are set for system check ON and Tach signal check on.
Jan 04, 2011 | DEI Python 1400XP Remote Start/Keyless...
A few weeks ago, my LG CU515's display stopped. Please help
Sometimes you can take the battery out while the phone is still on, wait a few seconds, and then pop it back in (this forces the phone to reset itself). If that doesn't work, take it to your local store.
If it's under a year old, it might still be under warranty and you can call 1-800-801-1101 for warranty replacement.
Jan 30, 2010 | AT&T LG CU515 Cell Phone - Black
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Sylvania 6842-PEM Flickering Problem
Something is breaking down. Possibly a specific ceramic capacitor on the main power pcb that has been troublesome. Usually there is just a loud pop and the screen goes dead. If the set is less than a year old it is still on parts warranty and the technician could just change circuit boards until the problem is gone.
Aug 30, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Raymarine RL70CRC GPS Receiver Logo
111 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
