Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Ice Maker Not Working
I am having problems with the ice maker. No water is coming in (only to the water dispenser part) and nothing on the ice maker, the arms or anything, is moving. This happened a few months back as well but it started working again on its own after about a day.
I did the optics test and I get 2 blinks when I open the door and the solid light when I press the emitter. I squeezed the black nozzle that goes into the water fill cup and a small chunk of ice fell out, so I thought it may be clogged similar to the issue others have had. I injected some hot water with a baster but that didn't solve the problem so far. One thing I noticed when I was injecting water was that some of it was dripping out the back of the fridge where the tube goes into the freezer at the top.
I wanted to pull the nozzle and tube out like in the service manual but there isn't much give. There is no fitting that allows the tube to be removed like it shows in the manual. The tube goes right into a valve type thing at the bottom back of the fridge and I'm not sure how to remove the tube.
I tried the trick putting a jumper between T and H but nothing happened. I'm not sure whether the ejector arms are at 2:00 or 10:00 but they point away from me when looking at it mounted. I read about manually making the water go into the ice maker through the solenoid, but how do I do that?
Sorry for the long post but any help would be appreciated.
  • 2 more comments
  • vik123 Dec 04, 2007
    Thanks a lot for the quick response. So here is an update: I was getting ready to try the solution you posted. I took the ice maker out of its mount and left it connected and sitting on the shelf. I also squeezed and moved around the black nozzle a little and a chunk of ice fell out.
    I went to double check your instructions and when I returned to the fridge I heard a noise that sounded like water. I opened the fridge and water was coming out of the nozzle and getting everywhere. The ejector blades were also now pointed towards me in the 2:00 position, which I assume is the home position?
    I quickly rushed to try and get the ice maker back on the mount but it was tough because of the tight space. By the time I got it mounted the water had stopped but I was hoping that the problem was fixed and was just an ice clog.
    I waited and kept checking on it periodically but nothing happened. I left it overnight and nothing happened. I then tried your instructions with the jumper and nothing happened. I checked the white gear on the module and it looks like one of the clips may be broken, but I'm not sure. One clip does stick out further than the other; I wish I could take a picture and show it. If it was broken though, would the ejector blades have been able to rotate from the 10:00 position to the 2:00 position?
    What should I do now? Could a clog in the line still be the problem? If so, how should I use a hair dryer? Should I just point it at the black nozzle where it comes into the freezer?
    Sorry again for the long post.
  • Anonymous Mar 19, 2008
    I have a 596.58697890 with ice maker that freezes up at the inlet tube a back wall. There was a metal tube connecting back wall to the tube going to the ice maker, i replaced it with plastic and that helped but it still freezes at the wall connection every few days. the hair dryer trick works, ice comes out of wall connector melts and then it works for a few days. replaced filter, checked flow to valve on refer, and checked temp settings
  • vik123 May 04, 2008
    Well it's been a while but I finally got around to getting a new module and trying to fix it.
    I disconnected the icemaker from the freezer and switched modules by
    taking out the 3 screws. I jumpered the T and H with a wire
    (about 2 inches long stripped 5/8th of an inch on one side and 1/2 inch
    on the other), plugged the icemaker back and then plugged the fridge
    back on.
    I waited 50 seconds and nothing happened. I tried a few more
    times and still nothing happened. I even left it there for a
    while but nothing happened.
    I'm not sure if I'm doing the procedure correctly but it doesn't seem to be working. Please help. Thanks.
  • ladymai May 11, 2010
    my refrig is 18 months old , my ice maker does not produce ice into the container. I can get the water out of the door.
I have Ge side-by-side refrigerator. There is no water coming to the ice make but there is water dispenser is working ok. I checked with electric tester the icemaker solenoid coil not getting 110V even the arm is down.
Posted on May 06, 2008
I just used the jumper wire and it worked!! I had to press and release the light switch 3 x before the gear began moving.
Posted on Mar 13, 2008
    President:
  • 878 Answers
Vik, the ejector blades should be pointing toward you in the 2:00 position when the ice maker is home. This tends to make me believe that your module is bad. Pull the ice maker out again and check the center white gear. There should be 2 clips holding it on. If one of those clips broke, the gear will not rotate right. Another thing you mentioned is that you had water on the back side where the line goes into the fill tube. You may have a frozen inlet tube too. If the tube is frozen, the pressure will force it out the back by that connection. Pulling that tube out can be a pain, try using a hair dryer if the baster not working. On this model, you can't just jump T&H to start the cycle because of the immiters. Follow these instructions to start a cycle.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Posted on Dec 02, 2007
  • Ron Marek
    Ron Marek Dec 05, 2007
    Vik, o,k, you don't have to worry about the frozen inlet tube, the water came. Im almost positive that your module is bad. The fact that one clip is out further is the tell tail. If that clip is broken the gear will ride off the motor and you will get erratic operation. The fact that you said the blades were in the 10:00 positon on your first post insures that. That module is easy to replace, 3 screws. Just line up the ejector blades in the 2:00 position when you put the new one on. You will save yourself a ton of money doing it yourself. Then follow my instructions again to jump start it when the new module is in. Catriver
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Ice maker stopped working water coming out of front of door. what to do?
There are two sides to a water control valve Cindy. One side for the dispenser and one side for the ice maker. Feel inside the ice maker slots for any remaining ice cubes. If the ice maker has no ice fill with tap water and if after the water freezes and drops the ice into the ice container and then does not refill with water the problem points to the dual water control valve. If the ice just sits in the ice maker and does nothing then this points to a defective ice maker. What is the model number of the refrigerator?
APPLIANCE 911
Dec 06, 2015 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Take the icemaker out and let it sit in the sink for around 12 hours. Then put it back in. This has worked for me when I have the same problem. I think that the water line is freezing up. I have to do this every month or two.
Mar 20, 2008 | Hotpoint HSM25GFRSA
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
1,239 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
