Question about Canon CanoScan 4200F Flatbed Scanner
Cannon scan 4200f light stays on
The light on my 4200f stays on even after scan is done. I am sure it did not do this before. I tried uninstalling software and reinstalling but light still on. Any help?
Thanks
  • Anonymous Jan 05, 2008
    Ditto and latest drivers installed. Light is on even when PC is off, i.e. just mains connected.
    Scholar:
  • 111 Answers
There is a lamp shut-off time adjustment in ScanGear. Go into ScanGear's Advance Mode and click Preferences. One of the four tabs will have an option for Lamp Shut-Off time. Set it as desired.
Posted on May 12, 2008
SOURCE:
How can i scanner my document
You need to install the scanning program first, it should be in a CD when you purchase the scanner. Install the program, install scanner to make sure that scanner works. Once it's done, you lauch a program, put you document in scan and scan it, the image should be saved into your computer.
Thanks
Aug 20, 2011 | Canon CanoScan 4200F Flatbed Scanner
My scanner is not work!! the error code is # 2,178,0!!! canner model is 4200f. pls help
Make sure if your scanning documents that the white plastic shield is on and if your scanning film this need to be removed. Make sure you also selected the proper item that you are scanning.
Mar 28, 2011 | Canon CanoScan 4200F Flatbed Scanner
I have a Canon Cano Scan 4200f. It worked in the
First, try unplugging and re-seating the USB cable in your computer. I am assuming your scanner is not making any noise when you first turn on the computer. If that is not the case, respond back with more information. This is the most common solution to this problem with these scanners though.
Dec 21, 2009 | Canon CanoScan 4200F Flatbed Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Adjusting the lamp
Hi,  This is normal for the 4200F and it's just the time taken to warm the scanning lamp up. Once it's warmed up it shouldn't need to go through the process again for any additional scans, unless it's had long enough to cool down again of course.
I've noticed from another answer to an earlier question that if it's a big problem you can change the following keys in your registry:
HKEY_CURRENT_USER\Software\Canon\ScanGear\8.6\Devices\CNQ4200
 Energy save changed to 1
 Lamp Off Time changed to 0
Looks like this would prevent your lamp switching off at all unless you unplugged your scanner which would undoubtedtly shorten your bulb life. It may be a better idea to play about with the 'lamp off' key number until it just stays on long enough to not cause you problem.
Cheers, Derek
Dec 24, 2008 | Canon CanoScan 4200F Flatbed Scanner
Can't get it to scan a picture
install the scanner driver first
if that is installed already.. uninstall and reinstall it
make sure that there are no error lights on the scanner
Aug 22, 2008 | Cannon Office Equipment & Supplies
Canon 4200F
Couple of things to check..
1. make sure your operating system is higher than windows 98 or make sure you install usb 2.0 drivers.
2. you can check this by going to device manager and make sure you have the 'enhanced usb' installed.
3. If you don't then there's your problem.
4. check to make sure you have downloaded the latest drivers
5. Try lowering the resolution of your scans. If you are just doing black/white scanning then choose that option and not hiqaulity full color scans.
good luck
smeags.
Feb 05, 2008 | Canon CanoScan 4200F Flatbed Scanner
I have a CanoScan 5200F
Because the slides are see through which means you will need a special add on for the scanner for it to support slides. If you have this already then make sure that it is fitted on properly so no light can get in the compartment where the slides are held during the scan
Jan 12, 2008 | Canon CanoScan 4200F Flatbed Scanner
Canon 4200f - Mac OS-X compatability
This solution does not work. On MAc there is no way to use this scanner. Canon sucks!!! There was no info about supported os on the box. It is just unfair to sell products without providing drivers for users.
Oct 24, 2007 | Canon CanoScan 4200F Flatbed Scanner
Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
Oct 13, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
318 people viewed this question
Clive
Clive
old marine
old marine
Ekse
