PSC QS6000 Plus Handheld Logo
Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
Robert Bivins
Level 2:
Sergeant:
  • Expert 192 Answers
  • Posted on Aug 20, 2009
Robert Bivins
Expert
Level 2:
Sergeant:
Answers
192
Questions
0
Helped
64549
Points
643
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Beeps but does not scan in the barcode
Sounds like you may have to re-install the driver..
download Driver & manual here
1helpful
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Psc qs6000 plus
If, during the programming session, you find that you are unsure of the scanner's settings or wish to reset the scanner's configuration, use the Return to Factory Settings label available in the Programming Overview section of the above programming guides. (Note: Use this label with caution, as it will disable ALL features that may have been programmed since the scanner's installation.)
Apr 08, 2008 • PSC QS6000
Psc quickscan 6000plus
That scanner has been constrained to accept a digit length of 12 or less .. probably IPC codes which are 12 digits in length.
Do you know the symbology of the barcode you are scanning? (i.e. UPC, EAN, I2of5, C3of9 etc).
2helpful
Obtain setup documentation
Here you go, hopefully this will work for you:
http://www.scanning.datalogic.com/html/manuals.htm
Specifically:
http://www.posguys.com/download/6000.pdf
If it does, please rate this as FixYa!
Thanks!
1helpful
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 • PSC QS6000
Top PSC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
