Question about Boston Acoustics MicroMedia Computer Speakers
Problem with boston acustics subwoffer
Left speaker output doesnt work
Check the volume settings. The speaker balance would have got tuned to the extreme right by mistake.
Posted on Apr 13, 2008
  • 38 Answers
> check it in another computer
> if problems persist check setting of speaker also connectivity
Posted on Dec 11, 2007
SOURCE:
How do I connect the speakers to a sb-wa350 subwoffer
Usually, it's the "stereo-audio-output" from your amplifier that goes to the sub-woofer, and then outputs from the sub-woofer to the left/right speakers. Or, if your amplifier has a separate output labelled "sub-out", then your connect your sub-woofer to that mono-channel output.
Oct 24, 2014 | Panasonic Televison & Video
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
No sound out of left speaker
To fix this I took mine apart. But I suspect it was the red and white speaker outputs. I unscrewed the screws and moved the red and white speaker outputs around and then put the thing back together. It now works again.
Aug 02, 2009 | Boston Acoustics MicroMedia Computer...
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
NO SOUND
the make and model of your computer dont matter to what speakers you hook up. i can take those speakers and plug them into my ipod, my computer, even my psp and will work.
i would first check ALL wiring and make sure is all conected corectly.
try plugging them into your ipod/mp3 and see if you hear sound? if not, its the speakers. If yes lets move on.
Plug them into your audio jack on your computer (THE BACK, Green audio Jack) usually your front audio jack if you have one is set to head phones and your rear audio jack is set to speakers.
Plug them in.
Go to Start, Control Panel, Sound.
Now make sure your speakers are conected and it notices it.
Me i have 3 Input devices that show up.
1) Speakers
2) Headphones or Audio 2nd Output
3) Digital Output
If you plug them into the back they will most likely but under #1.
Click Option #1 or the one that is labeled speakers and says "plugged in"
Towards the bottom select, Set As Default.
Apply Changes, Ok, and exit.
Now try listening to something on your computer.
If this still doesnt work, let me know.
Thanks
Feb 15, 2009 | Boston Acoustics BA735 Computer Speakers
No power to my subwoffer
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
Feb 09, 2009 | Boston Acoustics BA7500 Computer Speakers
MODEL QUESTION
I wasn't able to find a schematic diagram. Could you please send a picture or pictures from the top and bottom of your device. close ups of the circuitry from top and bottom will help to determine where that wire is connected to [email protected]
Thank you.
Jul 07, 2008 | Audio Players & Recorders
Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
Oct 25, 2006 | Boston Acoustics BA7500 Computer Speakers
Boston Acoustics MicroMedia Computer Speakers Logo
135 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
donny ardalando
donny ardalando
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
