Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
Melted plastic *bread wrapper*
How can I remove the melted plastic from a bread wrapper from my Jenn Aire glass top element?
  • 640 Answers
Mix vinegar and water in a container,turn the element on to the highest setting.get a METAL paint scraper pour the solution onto the element while scraping off the plastic.hope this helps.
Posted on Dec 02, 2007
SOURCE:
I have a GE HVM1750SM1SS and was defrosting some bread without seeing that there was a metal twist tie on the wrapper. In only a few seconds the plastic on the top started to melt and drip in the oven....
It sounds like you may be talking about the stirrer cover.
For some models, the owner's manual covers how to remove it. You can download GE owner's manuals and installation instructions here.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 27, 2011 | GE HVM1750SMSS Microwave Oven
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I need metal replacement stove knobs.
I was able to find online some metal knobs that MIGHT work, but the prices ranged from $30 to 60 EACH, and I needed 5 - too costly for me!
The following 3 plastic knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
I have installed the Amana knobs (#1), and I will report back if it proves unsatisfactory.
Dec 20, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Melted plastic (teapot whistle) on glass cooktop
Hello. I don't know if this will work but you could try getting it as cold as you can and maybe it will come off that way. If it were me I would use my refrigerant, but I am sure you don't have that. Who knows maybe ice will work. Now that I think about it, maybe you can carefully use some sand paper being sure you don't scratch the surface.
Nov 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Plastic melted on my glass cooktop
didi you try heating the burner slightly to soften the plastic a bit before trying to scrape off, cant see any reason why that wouldnt work, using a razor blade held flat will scrape just about anything off of the glass tops!
Apr 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Pitted glass cooktop in Jenn Air Model JGC9430ADS
Did you find anything out? We have had our Jenn-aire gas stove for 1 1/2 years and just noticed today that the surface has bubbled in a spot??? I did clean the oven last week.
Sep 10, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
330 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
