Question about Sony DCR-VX2000 Mini DV Digital Camcorder
Red vertical lines/no picture
The image on the viewfinder and LCD screen is composed of red vertical lines, which do seem to change depending on which direction the camera is pointed. This just happened. The camera has operated flawlessly otherwise since I bought it a couple years ago.
Frank
Hi there. Contact sony service centre directly and ask them about replacing the ccd. I have a vx2100 which did exactly the same thing. Sony admits that there was a problem with the ccd's used in these cameras and replaced them for free, maybe the same for your camera. good luck
Posted on Dec 27, 2007
No image, Just red and blue vertical line on display.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Hello, could you help me please? On a canon 350D how do you switch beween evf to lcd when composing a picture? I cannot find any button that facilitates that function.
On cameras like these you cannot compose a picture on the LCD screen. You have to use the viewfinder and check the results on the screen afterwards. The viewfinder is not actually an electronic viewfinder, you are looking through the lens via a mirror as was the case on film cameras. When you press the shutter the mirror swings up and lets the image through to the ccd chip just as if it was a film camera.
Apr 05, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a red line through my photos.
Answer ID 16497 Why do I sometimes see a faint vertical line in my viewfinder? Why do I sometimes see a faint vertical line in my viewfinder? --> With some DSLR cameras, a normally clear LCD screen is used to display Auto Focus area brackets in the viewfinder. When power is supplied to the screen, you may sometimes see a faint vertical line appear in your viewfinder. This is perfectly normal and is just part of the finely etched circuitry used to power and illuminate the liquid crystal segments of the AF area brackets.
Jul 24, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Red flashing indicator in viewfinder of my Canon XL1E
Hi . .  I downloaded the manual . . found I needed to replace the 3 volt lithium battery located on the underside of the hand grip for the zoom. Changed the battery . . . No red flashing icon in the viewfinder.
Cheers
Steve
Feb 28, 2009 | Canon XL1E Mini DV Digital Camcorder
LCD Screen dead
This may be a dumb idea... but did you accidentally turn the screen off? Don't ask how I know this...
Dec 26, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Vertical Red Lines
IS IT AN LCD ? IF SO IT MAYBE THE CONNECTOR ON THE LCD PANEL THET USUALLY GO DRY JOINTED
Oct 08, 2007 | Akai PDP-4216M 42 in. Plasma Television
Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
Sony DCR-VX2000 Mini DV Digital Camcorder Logo
121 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
