Question about JVC KD-S6060 CD Player
Resets when car ignition is turned on.
Since I have had the player, every time I turn on the ignition, the presets reset meaning I have to retune all of the radio stations again. The garage that sold me the car fitted the CD player for me. I drive a Vauxhall Astra. Is this likely to be one the cars where the yellow and red wires need to be crossed over? I am worried that if I disconnect the player I will have to enter the code (which I don't have).
YOo i hAD tHiS SAMe pROb.yEStERdAy..i SwitChEd tHA WiRES[red & yellow]
iT WORkd..bUt i jUSt hAtE tHA WAy it lOAdS tHA CD..
[do it!]
Posted on May 08, 2008
You will need the code unfortunately, you can patch in a pp3 9volt battery but it is akward.
i suggest you go back to the garage and let them have a go swapping the wires round
Posted on Dec 14, 2007
SOURCE:
I have just fitted a pioneer DEH-1320MP to my golf but the radio will not hold the presets when turned off. So every time you strart car you need to retune the resets on the radio. Is this something to do...
Yes, someone forgot to hook up the lead that says Batt + to a constant battery + voltage , this will keep the presets on the radio when the key is off, unless you disconnect the battery.
Jul 07, 2011 | Car Audio & Video
Memory resets when car turns off
hello sapphire pla,
sounds like you have no permanent 12 volt on the player. you need to connect to (usually) orange wire on player. if it is connected to the ignition key then every time you turn off all memory is gone.
feel free to contact me here under your topic if you need further assistance.
regards
Jun 08, 2011 | Sony MEX-1HD CD Player
Radio resets when car is turned off
There is a yellow wire in the harness coming out of the head unit, this should be connected to a constant power. This circut maintains power to the head unit for the clock and memory.
The red wire should be connected to a source that is turned on and off with the key switch.
Jun 01, 2010 | 2003 Ford Focus
Radio resets to AM
Take out your radio and make sure that the memory wire is getting a good connition(yellow wire)
Apr 08, 2010 | 1998 Chevrolet S-10 Pickup
The maintenance required light on my wife's 2004 Hond Pilot is blinking 10 times when she turn on the ignition. It started doing this after I put in new plugs and an oil change. What does it mean. I...
to reset your maintenance light follow the following steps:
1 Turn off the engine.
2 press and hold the select/reset button in the instrument panel, then turn the ignition switch ON
3 hold the button for at least 10 seconds, until the indicator resets.
Jun 26, 2009 | Honda Pilot Cars & Trucks
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Everytime i take turn the car on or off the radio resets to defau
If you are losing the memory (clock and presets) on the unit, you need to make sure that the yellow wire (normally) has 12 volts AL THE TIME and the red (acc) is switched on and off with the key. The battery wire (memory consant 2 volts) is the one that retains memory.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 05, 2008 | XO Vision XO9013 Car DVD Player
Pre setting the radio station on the keh-p2800 cassette player
HAS TO BE A CONSTANT POWER WIRE THAT CONTROLS CLOCK AND SETTINGS SHOULD BE A 16-14 GUAGE WIRE THE SAY 12+ AND HAS TO BE HOOKED INTO A CURCUIT HAS IS POWERED ALL THE TIME (NOT ONLY WHEN IGNITION IS TURNED ON)
Jul 12, 2008 | Pioneer KEH-P2800 Cassette Player
Kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
May 27, 2008 | Kenwood KDC-2011S CD Player
JVC KD-S6060 CD Player Logo
158 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
