Hp pavilion n54212L
Need a quick tour --how to get the machine turned on for one, the other is is there a mains conect cable with just the three point plug, to replace the two prong plug, ??thanks arthur
    Novelist:
  • 77 Answers
To turn on an HP, make sure you have the AC adapter plugged in properly, and press the power key. But since you imply it has been a while since this was on, I suggest removing the battery BEFORE you start the first time.
The power key is identified by an ICON best described this way: a circle with a vertical line in the center. The vertical line is sometimes centered in the circle without touching any edges, and sometimes it is crossing the top of the circle slightly.
Once you have started the laptop and get to an OS desktop, you should check everything out to make sure everything works.
Then SHUT down, remove the power supply, insert the battery, reattach the power supply and start again.
Monitor the battery charge progress carefully. If the battery fails to charge, it will need to be replaced. This is because no matter how new a battery is, if it is left for extended periods in an uncharged state (or worse, fully depleted state) the battery will usually be defective. It cannot ever be recharged because at least one cvell will be dead.
As for the power cord, using a three-prong plug will be useless if you do not have a 3-prong jack and 3-wire cable. but if you do, you can cut off the useless 2-prong euro plug, strip the 3 wires and install a 3-lug grounded plug. Pay attention to the polarity then, because it is critical on 3 wire connections. In USA, black, white and green are the color codes. Green is the ground. In Europe, the colors are different and varies widely. Blue or brown will be the ground. You will need a VTVM to trace the continuity to the other end, to identify which is load, neutral and ground (earth). Be careful. Ifr you connect AC load to ground, you may damage your PSU -or the HOUSE !!!! :)
Posted on Feb 11, 2008
SOURCE:
Wifi on hp pavilion 7915
After looking at the specs for this machine:
Model number
P1062A
Processor
Intel Celeron 1GHz
Chipset
Intel 815b
Bus Frequency
100 MHz
Memory
  • 256 MB SDRAM / 133
  • Two DIMM Slots
Storage
  • 20 GB Ultra DMA hard disk drive
  • CD-RW 12x8x32x rewriteable drive
Communication
  • 90 K56 PcTel Modem
  • Network Interface (integrated) 10/100BT
Video
  • Integrated into Intel chipset
Sound
  • Integrated AC97 Audio
  • Two Polk Audio premium stereo speakers
Accessories
  • HP Internet Keyboard
  • PS/2 Scroller Mouse
Ports and expandability
  • Five expansion bays (free: 1 - 5.25 external, 1-3.5 internal)
  • One AGP (free)
  • Three PCI (one PCI free)
  • Four USB (two in front)
  • One parallel port
  • Two serial ports (one in front)
Complete software package
Supported operating system
Microsoft (R) Windows Millennium Edition
Productivity
Microsoft Works Suite 2001
  • Microsoft Word 2000
  • Microsoft Works Standard 2001
  • Microsoft Encarta World Atlas 2001 (English version)
  • Microsoft Picture It! Photo (English version)
  • Microsoft AutoRoute Europe 2001 (English version)
  • Microsoft Internet Explorer 5.5
  • Microsoft Outlook Express
  • Smith Micro QuickLink III (fax)
  • Adobe (R) Acrobat (R) Reader
Internet and online
  • Free2Connect
Service and support
  • HP Pavilion Online User's Guide
  • HP Help
  • HP Tour Guide
  • HP Pavilion Recovery Kit
  • ActiveShield PC Clinic by McAfee
Entertainment
  • Adaptec Direct CD, Easy CD Creator and UDF Reader
  • MusicMatch Jukebox
  • ArcSoft "My Photo Center
It appears that this machine does not have a wifi network adapter. You will need to buy / install a wireless adapter for this machine so you can connect to a wifi network.
Oct 27, 2012 | HP Pavilion 7915 PC Desktop
What cable do I need to conect my HP computer to my Element TV?
check computer and tv for same type of conection - VGA, DVI, HDMI
Oct 15, 2012 | HP Pavilion dv4-1028us 14.1" Widescreen...
My hp pavillion mx 50 montior dosent turn on and if it does the green light on turns to an orange what to do to fix it
Check your Monitor Cable at the back of your PC unplug it and chec for bad pin conection make sure your Monitor cable are plug in correclty....
Oct 01, 2010 | HP Pavilion MX50 15" CRT Monitor
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
HP DV6917cl Pavilion laptop Quicklaunch lights will not turn off
From what i can remember with HP laptops there are two ribbon cables that rup up the left hand side of the laptop which both look the same. One to the power button the other to the LED's and hot keys on the keyboard bezel (plastic strip that runs above the keyboard)
You may have accidentally used the wrong cable in the wrong slot. Try reversing the cable. power on and see what happens. You can also try to switch ends to see if that helps.
Let me know if there is anything else.
Regards.
Feb 08, 2010 | Computers & Internet
Hp Pavilion dv2601tx Quick play not working
uninstall with revo uninstaller and install 3.2 back
Oct 25, 2009 | HP Pavilion dv9000z Notebook
Why isnt my ethernet cord detected by my modem
Three points of failure: modem is not working faulty ethernet cable or clamps non-functional network card
Jun 07, 2009 | HP Pavilion dv6000z Notebook
I need to turn built-in webcam on
use HP quick play to view web camera make sure you have the latest updates fr quick play to found at hp.com
thanks
erik
Feb 25, 2009 | HP Pavilion DV6910US Laptop
Hello i purchased a new hp pavilion about three days and the battery fade away quickly.
hi!!!!
if it is under warranty try
replaced it in the store where you bought
your hp pavilion!!
Oct 30, 2008 | HP Computers & Internet
Open Questions:
Computers & Internet Logo
114 people viewed this question
Ekse
Alun Cox
