Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
MY RCA TVE WONT TURN ON
I HAVE AN RCA MODEL NUMBER D52W20 IT WONT TURN ON IF i TURN ON THE TV THE POWER LIGHT TURNS ON BUT NO PICTURE AND SOUND THEN IT SHUTS OFF WHAT IS IT?
  • 6 more comments
  • SPARKLES69 Dec 02, 2007
    ITS THE TV IT SELF ITS NOT THE REMOTE..
    I JUST UNPLUGED THE TV AND PLUGED IT IN ANOTHER OUTLET IT IS STILL DOING THE SAME THING THE POWER LIGHT TURNS ON AND THEN SHUTS OFF NO PICTURE NO SOUND .
  • Anonymous Apr 22, 2008
    I have the same exact problem with my 52 inch. Turn it on and you get picture for one second and then it cuts itself right back off. Dont know what to do with it!
  • Anonymous Jun 05, 2008
    I have a RCA modle number 32v434T.The light comes on when you turn it on but there is no picture or sound.Only had TV for a year.What is it?
  • billie_abram Mar 21, 2009
    I have the same problem with my exact same model tv. It tries to turn on 3 times in a row by it's self but then stops and never comes on. Then I push the power button like 50 times before it will try to come on and still it never comes on.
  • LIL_h52va Mar 23, 2009
    MY 52'RCA PROJRCTION HDTV JUSTED WONT CUT ON
  • Anonymous Mar 23, 2009
    WOW i'm having the same issue with my tv. It tries to turn on a couple of times then shuts off.
  • toshatpatter Mar 26, 2009
    Mine is doing the same thing. any luck yet? Fo they have fuses?
Did you change your battery from the remote?
Posted on Dec 02, 2007
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA rear projection wont turn on the light flashes when i push the power button, i got it to turn on once and i had a vertical line running through it. and colors a little distorted, i tried in the menu...
The flashing light opposed to a solid pwer indicator light usually means it needs to be serviced. I wouldn't reccomend home repairs, but repairs sometimes cost more than the product. You should compare prices and such before making your move.
Aug 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below.
Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry. TV is powering off most likely to protect itself from the shorts.
Dec 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
613 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
