Question about JVC Everio GZ-MG130 Camcorder
Changing output and input
Cant figure out how to cahnge from output to input on camera
  • 32 Answers
Hey its there in the manual! If you dont have it let me know..
Posted on Dec 02, 2007
SOURCE:
Problem? * The signal from componenant input,RGB,@ 1080i + 720p,doesn't work at all when outputting at component output or HDMI. 100% failure.
you cant record an hd picture and sound through component input rgb,for 1 you arent inputting hd,you are inputting analog,you cant up convert,
Apr 16, 2015 | Televison & Video
Soundbar wont work
It basically has an Optical input, or a coaxial input. Use whichever input is available for you from your TV digital output, to the soundbar. If it still doesn't work, the soundbar is probably damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 27, 2013 | Philips CSS2123B/F7 SoundBar Home Cinema
Write a programme that takes three numbers as input from the user and find out wheather one of the three numbers is the airthmetic mean of the other two. for example : input: 7, 11, 15 output: 11 is...
Since you are taking a class in binary programming; I would recommend you figure this out yourself. The major point in logic class is to determine ways to solve this on your own. If you are unable to do this; I would suggest a change of major.
Jan 29, 2011 | Computers & Internet
I want to record onto my DCR-VX2100 from another video camera. What inputs are available on the unit?
s-video input/output and RCA input/output. You can change from input to output via the menu.
Dec 13, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
Cant figure out where batterys go
It may be the canon camera software problem,or the canon battery output wire have some problem,that will be a trouble matter.Good luck.
May 14, 2010 | Canon Sure Shot 80 35mm Point and Shoot...
Cant figure out to hook up keeps saying no signal with hdmi cable to tv and blu ray put in
What kind of TV are you hooking the dvd player up to ? You may have to go into the TVs menu and set the input to the proper resolution or input style to see a picture. The dvd outputs a 1080i and if the TV is set to 720p it may not show a picture, the dvd output can also be changed to match the TV.
Sep 06, 2009 | Samsung BD-P2500 Blu-Ray Player
Car runs regardless of remote, it responds to change of direction, but you cannot control the car stopping or going. When you turn the car on, the wheels just start going.
cahng the baterries of the remote control for a brand new if the problem still you cant fix it contac tyco to see if they can check your car
Jun 15, 2009 | Mattel 1:32 Scale Tyco Radio Controlled...
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
JVC Everio GZ-MG130 Camcorder Logo
37 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
