Question about Thomson LCDB 03B 27 in. Television
Thomson 27" LCD TV 27LCDB03B
Our TV comes ok, but after a while (5-20 minutes) the screen goes blank but the sounds still comes through. After switching off the TV for few minutes and back again it comes back on again, but then it goes blank again after a period (5-20) minutes.
Can you asisst and maybe point out potential faulty component/s?
Many thanks
Regards
Patrik Koppanen
  • 2 more comments
  • geek01 Jan 06, 2008
    I have the same problem with my Thomson 32" LCD TV. Help!!!
  • Barkie11 Feb 21, 2008
    Same problem here!
  • Anonymous Apr 17, 2008
    Help, i have exactly the same problem with my TV !
  • edu5436 Sep 01, 2008
    Same problem with a 20'' Thomson LCD TV.
    New Friend:
  • 182 Answers
Cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Posted on Jun 11, 2010
SOURCE:
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
if you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Jan 06, 2013 | Thomson Televison & Video
Thomson 27lcdb03b picture upside down
I would suspect main board more than one you replaced--not likely to get help as Thompson is not known for that--possible firmware upgrade seems likely.
On every set I have seen with upside down/inverted or reversed screen etc it has been either a firmware issue or a main board.
Jun 07, 2012 | Televison & Video
Screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Feb 11, 2009 | Thomson LCDB 03B 27 in. Television
Thomson 27LCDB03B
If all the voltages measure normal, the failure could be in the LCD's inverter board. I've checked the schematic and it seems like the 16 volts could be a bit higher, check the electrolytic capacitors filtering the voltage for the inverter board.
Click here to download the service manual.
Good Luck.
Sep 12, 2008 | RCA HD50LPW175 50" HDTV
TV LCD THomson 26"
If what your saying is that there are vertical stripes down the screen, You have a screen drive problem my friend. This could mean you will need to change the entire main board, the screen driver board if it is separate on this set, or the main LCD panel itself. These boards do not have any parts available for them and must be replace as a whole unit. Good Luck
Mar 19, 2007 | Thomson 20LCDB03B 20 in. Television
Thomson LCDB 03B 27 in. Television Logo
2,123 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
