I need to replace the bearing in an AEG Lavamat 1450. I've taken the back off the machine, but there isn't a traditional "spider", just a round wheel type thing attached with an Allen bolt.
Can I have some advice on how to remove this so that I can get to the bearing.
Hi there.....unless your exerienced in this area...id advise you to seek expert help...the drive wheel securing bolt is of the torx type and requires a secial torx key to remove it....you will find that the outter drum has a series of torx headed screws around it which have to be removed and then the drum split...only after this has been completed and the inner drum removed will you have access to.the bearings.......
I have a Simpson Encore 703 and there is uncontrolled filling problem with it (only the cold water),...
(More)
I have a Simpson Encore 703 and there is uncontrolled filling problem with it (only the cold water), otherwise it is perfect. Can anyone tell me what can be done to fix this problem. I will be much obliged.
