Question about Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Good Day:
I own Amana model number BX22A2W.
Amana refrigerator with bottom freezer - Freezer works, no air circulation to refrigerator compartment. Compressor and condenser fan run. Freezer is cold, and evaporator fan runs in the freezer compartment, but no flow into the refrigerator. There is no frost on the unit. What should I do next?
- Thank you
  • 2 more comments
  • Anonymous Jul 11, 2008
    Amana side by side refrigerator--model ARS2667BS--appreoximatly 4-5 years old--
    Freezer seems to be doing fine--refrigerator side is warm--
  • lanphuongvu Aug 26, 2008
    I have a subzero 690, 5 years old, Freezer works great, Fridge is not cold, temperature is at 59-61, should be at 42. Freezer makes ice, cold, nothing seems to be the problem. Please help. Side panel is so hot. It seems to adjust by the outside temperature. On a cool day, it goes down to 49 instead of 59. Thank you.
  • steven888 Nov 01, 2008
    I have the same problem. Please advise.
  • Anonymous Nov 12, 2008
    Same problem.  Freezer works fine but fridge is not cold enough.  set to 7 which is the highest temperature allowed.
    Problem Solver:
  • 6 Answers
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Posted on Jun 13, 2010
Had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
2 Suggested Answers
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
I have a fridge with the freezer on the bottom, model#ARB190RCW. the freezer is working but the fridge is warm!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 24, 2011 | Amana Refrigerators
Amana bottom freezer model ABB2227DES--food in fridge is freezing when it didn't before.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Amana ABB2227DE Bottom Freezer...
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
Amana,BX22A2W Freezer works, on bottom, Fridge is not cooling, no fan.
This is a common problem and most of the time it is one of two things. Ice can build up stopping the fan or the fan is bad. Before changing the fan unplug your unit over night and let it defrost to make sure that ice is not the problem. If the fan works after that then also check that the defrost timer is not bad, which could be the reason that you have ice build up. If your fan still does not work and manual defrost then replace the fan.
I hope that this will help you to solve your problem.
Nov 20, 2009 | Amana 18.6 cu. ft. Bottom Freezer...
Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
2,261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
