Question about Panasonic DMR-E55 DVD Recorder
No 7.5V supply to fan
After replacing IC001 machine functions perfectly (using temporary cooling)
Circuit Info required re source of 7.5 fan supply.
  • vk101 Dec 08, 2007
    I have the same issue, my fan not running on when unit is turned on, it works when removed and 7.5v is applied.Suspect no power being supplied, is this due to the IC001 ?
  • maintman84 Dec 09, 2007
    I would not think fan not working was anything to do with IC001 since recorder works perfectly with external fan positioned over grill after internal fan is removed (for prevention of other overheating damage). The guess is that there is a dedicated 7.5v regulator which caused a lack of cooling. Maybe IC2 this could be established instantly from a curcuit diagram!!!
    maintman84
Palmbeach has the correct diagnosis. The heat sink fitted to the IC001 is not adequate. I have removed screw and fitted an additional heat sink to the FRONT of the IC. The original heat sink is fitted to the BACK. Put a spot of thermal compound on the front and back of the IC.The additional heat sink is made from a piece of aluminium strip 30 mm wide and cut to 65mm (or there abouts) long. Cut two slots to clear the original heat sink where it is bent round at either end. The strip is 2.5 mm thick. Remove the self tapping screw and replace with a longer machine cut screw and a nut. This allows you to get the correct tightness. You will have to drill out the hole in the present heat sink slightly so be very careful.
When testing the repair put the cover back on so that you get the correct air flow from the front of the case out through the fan.
As Palmbeach has said the fan is thermostatically switched and does not run all of the time. This mod can be done with the minimum of change to the original. About 20 minute task if you have the tools. Thank you Palmbeach
Posted on Feb 06, 2008
  • dengle Feb 11, 2008
    It very much depends on the ambient temperature around the recorder. If it is in the sun, near the heating radiator or in a cabinet with other equipment you can expect it to start immediately. if it is sitting in an ambient of 20 centigrade or less it may not start immediately and it can take between 10 to 20 minutes to start in record mode.
    Dengle
  • 3 Answers
I agree with Palmbeach - The PSU board contains a number of Thermistors which are devices that change their resistance with temperature, therefore when the unit gets warm enough to warrant the use of the fan it will power up !...Revieski
Posted on Jan 09, 2008
Further to my first posting, my brother has the previous modele recorder his fan comes on as soon as the unit is switched on I was assuming the later model would do the same, can anyone confirm this ?
Posted on Dec 26, 2007
  • 185 Answers
Before pulling out components, take into consideration that the fan does not necessarily operate as soon as the unit is powered. It should operate when the unit has been switched on for a while. Regarding IC001, I have long felt that this component should be bolted to a proper heatsink and fixed to the inside of the cabinet with a suitable insulator. DO NOT DO THIS WITHOUT A SUITABLE INSULATOR. The cabinet would make reasonable heatsink and IC001 would only get marginly warm.
  • Palmbeach
    Palmbeach Dec 26, 2007
    The fan is thermostatically controlled. In other words, it should only operate when the temperature reaches a set level. If it operates as soon as the unit is switched on, it can only mean that the unit is in a very warm place like adjacent to a heating radiator, or that the thermostat is either out of tolerance or could even be short circuit. The E55 will generate a little heat even in stand by, so first, I would ask your bro to check that the vents are not being obscured. Also, run you own machine or a while and see if your fan eventually operates. It probably will.
SOURCE:
I have a 2006 buick lucerne 3.8 v6 cxl.my coolinf fans dont come on .i need to know how to change the relay and the fuse.
Your vehicle cooling fan's are controlled by three relay's , couple of fuse's an the PCM - engine computer . The engine coolant temp. sensor is a input to the PCM , when engine temp get's to 212 the PCM will turn on the cooling fans in low speed . Checking to see what the actual temp is with a scan tool an a infrared thermometer at the thermostat housing ,an looking up the specification's in a service repair manual is how to diagnose . Not guessing an replacing parts . Plus learning how the cooling fan's work .
Relay Driven Dual Cooling Fan Diagnostics Reading factory service info as to how they work also would be a good idea .
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Dec 10, 2017 | Buick Cars & Trucks
I have a neff B6774N0GB combi oven. Activated the hot air button and it has tripped the circuit breaker. Fan element examined and looks perfect. Oven is isolated from other appliances
The hot air function uses a great deal more current than the other functions. Check the tag on the oven for current requirements, and check the rating of the circuit breaker in use. If the breaker is rated lower than the ovens rated maximum current draw, it will trip under the load. If the rating of the breaker is above the ovens maximum current draw, and there is nothing else plugged into that circuit, the breaker may need replacement.
Sep 14, 2016 | Neff Microwave Ovens
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
My power supply in my phonic helix mkII 24 board is blown, it was messed up in a power surge, I have tested the remaining connecting parts and everything else is fine. I contacted phonic and they dont...
Usually it's the electrolytic caps that go in those, they basically "cook" and dry out, a power spike just pushes them over the edge. I've also had this problem with mine & 2 12 volt switchers for my HD and for the satellite had the same fix. I added a fan which helps. Another solution is to go to a second hand store, find 3 power suplies (15v,15v, 5V) and put them in place of the existing one. I am considering that myself as the firewire packed it in again last month and I had to jump over to the other 5v regulator to get it going again, even tho it was only 0.2 v short! Cheers, Sandrine
Jun 20, 2011 | Phonic Helix18fw 18 Channel Mixer with...
Service engine light is on and code P0526
The Powertrain Control Module (PCM) uses the cooling fan speed signal in order to determine the actual fan speed in relation to the desired fan speed. The PCM uses the cooling fan speed signal in order to reduce the cooling fan noise and in order to maintain the powertrain cooling requirements. The PCM supplies power and ground to the clutch hall effect sensor of the cooling fan clutch. The hall effect sensor returns a signal pulse through the speed signal circuit in response to the reluctor track, which is located inside the fan clutch. If during operation, the PCM detects a loss of the cooling fan speed signal, DTC P0526 will set
  • An inline connector could cause an intermittent DTC. Ensure to test for poor connections and pin retention at all inline connectors. Refer to system schematics for connectors and locations.
  • If the condition is not present, refer to Testing for Intermittent and Poor Connections.
  • Disconnect the harness connector of the cooling fan clutch from the shroud. Inspect the exposed wires between the harness connector and the tubing.
  • Inspect the cooling fan clutch harness in order to ensure that the clutch supply voltage circuit is not shorted to the following circuits:
  • The 5-volt reference circuit.
  • The cooling fan speed signal circuit.
  • The low reference circuit.
  • DTC P0526 will set if the engine is started without the drive belt ON.
Mar 05, 2010 | 2004 GMC Envoy
My computer isnt powering up, what should i do?
r u a professional..??
assuming that ur bios is not flashed, in a wrong way..
all fuses to mains supply are ok, including all wiring circuitry..
if so check--
the system battery for above 3.0v
all smps output signals are ok..ps-on(green +5v);
pg(violet~+5v) & sb(grey~+5v); (orange~+3.3v);
yellow (+12v); red (+5v); white (-5v); blue (-12v);
ground (black~ 0v)..
the cpu..
..replace the smps/cpu/battery with standby n check..
..contact ur system admin/vendor....
Oct 27, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Need to know "no bus" indicator light on instrument panel....
"No Bus" means the data cable going to the (PCM) computer is unplugged, or the PCM has failed and not able to read the information it is being given.
Sometimes just jiggling the PCM causes the ODO "NO BUS" to come on.
Sometimes a bad crank or cam sensor can cause this as well.
Here is the OFFICIAL checklist for the "NO BUS" condition....
Vehicle: 1998 - 1999 Dodge Durango 3.9L
2000 - 2001 Dodge Durango 4.7L
1998 - 2000 Dodge Durango 5.2L
1998 - 2001 Dodge Durango 5.9L
Symptom: Engine will not start. Gauges are inoperative. No BUS message displayed on odometer.
System: Body/Chassis Electrical, Emissions/PCM/Fuel, Engine Electrical
Codes: N/A
Problem 1 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Crankshaft Position (CKP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) sensor. If 5v is not present, unplug the Crankshaft Position (CKP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CKP sensor.
Problem 2 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Camshaft Position (CMP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the Camshaft Position (CMP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CMP sensor.
Problem 3 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Manifold Absolute Pressure (MAP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5v power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the MAP sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the MAP sensor.
Problem 4 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Throttle Position Sensor (TPS).
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5 volt power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the TPS. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the TPS.
Problem 5 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted wire.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the throttle position sensor (TPS) or manifold absolute pressure (MAP) sensor. If 5v is not present, unplug all sensors that are connected to the 5v power supply and disconnect the PCM. Check if either 5v power supply circuit is shorted to ground using a DVOM. If the circuit is found to be shorted to ground, repair the wire and the cause of the short.
Problem 6 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Governor Pressure Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the large round connector on the driver's side of the transmission. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, remove the transmission pan and check for shorted wiring inside the transmission. If the wiring is OK, replace the Governor Pressure Sensor.
Many times the PCM simply overheats - and changing it will stop the problem.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | 1999 Dodge Durango
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
Trouble with my Panasonic DVD recorder DMR-E55EB
Hi Dengle
The heat is caused by IC001 which is a regulator that is mounted on a completely inadequate heatsink on the power board. This component gets very hot during normal operation.
The regulator will usually last a couple of years, depending on how often the machine is used and then start playing up. The symptoms are intermittent operation, continuous self checking and rebooting, not being able to read discs and so on.
Eventually the component can short-circuit, burn out and take other components with it. The on-board fan is thermostatically controlled. It does not operate all the time, only when the unit gets hot enough. By using an external fan, you are keeping the unit cool enough for its own fan never to cut in. The additional cooling is probably squeezing a bit more life out of the regulator and is stopping its own fan from operating.
I have repaired lots of these and have never found a faulty fan, or fan switching fault. There's always a first time of course.
It is more likely that the regulator IC001 is faulty and if you are technically skilled, I would suggest you seriously consider replacing it. Use some heatsink compound and an extra heatsink, and it will probably do the trick. The regulator is an STRG6353. You can get these easily online from a number of outlets. Don't attempt a repair if you are unsure of what you are doing. Regards..
Nov 18, 2007 | Panasonic DMR-E55 DVD Recorder
Powerdown after a few seconds
Amazing - I have exactly the same symptoms on my DMR-E55EB - noticed the dead machine on 19/11/6 - tried several powerdown resets, gained a few tens of seconds operation each time, and after around 6 attempts it died completely. Will open it up and have a look...
Nov 13, 2006 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
