I forgot the pin number for the atm and now I have no idea how to reset it. I tried to press the reset button, but it still refuses to let me change the pin.
I
change the pin.
who do i contact to change pin number of my post office account. i do not know the current pin numberwho do i contact to change pin number of my post office account. i do not know the current pin number
You can't post conmments that contain an email address.
There is no way I can pluck this out of thin air. You need to contact your bank and get them to reset your ATM pin number, then you need to change it straight away so you are the only one that knows your PIN number. Record your PIN number and keep it in a safe place, if someone knows your PIN they can empty your bank account.
Answer: 1. Insert your ATM card into the slot with the holes pointing down 2. The auto teller will ask you to enter your PIN code. 3. Press and hold keys 1 and 2 until the screen reads, "Reset PIN." 4. Enter a new four-digit PIN code, and then press the "e" key. 5. Enter your new PIN code again to confirm. Press the "e" key. 6. The ATM Safe will restart.
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
We had the same issue -- the name could be reset, but not the pin could not.
Finally, I realzed that when it is reset by using the reset button or the batteries, the PIN is reset to the factory default of 1234. Don't try using your old pin at this point -- enter 1234 as the pin.
Once you have the bank working again, theoretically you can reset your pin to whatever you like by hitting enter twice. I say theoretically because we're sticking with the factory default for now.
