Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Model FFU2065FW4 - manual says nothing about lights at bottom
Just got this freezer and there are two lights and an ON/OFF switch on the bottom panel in the front. What are these for? The manual says nothing about them and I can't find documentation on this site.
  • Keith_R Dec 31, 2007
    Thanks, I finally figured that out. But how tough would it've been to have inserted a comment in the manual to that effect, something like: "When the freezer is initially installed, the red 'Temperature Too Warm' indicator will be lit. After a few/several hours of operation that light should go out, indicating that the freezer has cooled down to proper operating temperature. At this point the Temperature alarm switch, if provided, may be turned on." And maybe a picture of it as well ...
    On a different note, how stupid is it to locate the temperature control on the BACK WALL of the freezer BEHIND all the stuff one is storing on that shelf?!? It would have been simplicity itself to locate the control on that same bottom panel as the Temp Alarm switch and indicator. <> Engineers ... <>
  • Anonymous May 04, 2009
    My freezer ran fine for two years. Tonight the alarm went off, both lights on the bottom panel were on. No manual, the freezer is full and against a wall so I can't get behind it to get model number, etc. Fortunately these comments have provided me with something to look for (the temp gauge on the back wall of the freezer inside). So when does the alarm go off? Can I leave it on? What does the on/off switch turn on or off?
HI THERE. I HAVE A PROBLEM WITH MY FREEZER.. I HAD IT TURNED OFF FOR ABOUT 3 MONTS AND NOW I NEED TO USE IT AND THE temp gauge on the back wall of the freezer inside IS ON BUT STILL SHOWING "0"NUMBER IN IT AND DOES NOT CHANGE WHEN I PRESS IT.. ITS 24 HOURS SINCE I PLUG IT TO THE WALL... WHAT DO YOU THINK IT COULD BE THE TROUBLE? .
Posted on Oct 10, 2010
  • 51 Answers
The switch turns on and off signal that lets you know that the freezer is to warm. One of the lights dose the same and the other is a power on light. All's well.
Posted on Dec 07, 2007
I have a FCM5SUCWW GE freezer and there are 2 unmarked toggle buttons/switches next to the light by the control panel. What are they for? The manual says nothing about them.
They are usually for extra ddehumidification based on the area you live in. If your freezer is working correctly, I would just leave them where they are at
Aug 17, 2016 | GE Freezers
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Freezer light doesn't work and door ajar alarm going off
The door switch is faulty. It switches the light on. There is no battery.
Dec 27, 2012 | Kenmore Freezers
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
553 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
